ash,
noted. I am along for the ride on this one. prices have been discussed already internally. for the sake of my sanity I would prefer they were not made public. call me if you wish to discuss this.
guys put this where it is required.
one lol and would like to keep it one
but im flexible
@op
move to melb section ?
So when that key fails at 3 in the morning 500 km out of MLB what are you going to do?
Ok guys this has now been moved to "group buys" of the classifieds section.
So far everything has been positive and we are getting numbers.
Melb: Car Alarm Supply & Install http://www.skylinesaustralia.com/forums/index.php?/topic/437322-Melb:-Car-Alarm-Supply-&-Install
Edited by Lifted
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
