I have a Stagea 260RS with a RB26DETT. It's had a Vipec V44 fitted for 5 years or so now. One thing that has always bugged me and I haven't been able to solve is engine starting when warm. If the engine is cold, it starts straight away. If I shut the engine down and start it 10s later, it starts straight away. If I shut the engine down for a few hours (sometimes up to 8 hours) it always takes a lot of cranking. At first I thought this was a tuning problem and my tuner added more cranking fuel. It may have made a minor difference. A friend and I had another go at it 6 months ago and added more fuel. It seemed to improve the case where you shut down for 10s, but still if the car has been left for a while I have the normal problem. When it does eventually splutter to life, it pumps out a bit of black smoke, so I'd say we've gone too far with the fuelling now. I'm beginning to think this is not an ECU problem, so I was wondering if anyone on this forum might have some ideas of what else I can check. I was thinking it could be an injector that is slowly passing when the engine is off. I had all injectors cleaned and tested when the ECU was fitted, but perhaps they didn't pick or test for this. Any other ideas?
https://www.sau.com.au/forums/topic/437453-rb26dett-problem-starting-when-warm/
I think it would be tune issue. It's hard to set up all of the parameters, and to get it nearly as good as factory is really hard.
I am suprise the cold start is good, usually that's the difficult one to get right.
How does is sound while cranking warm, does it sound like the starter struggles a little to turn the motor over, sort of like the battery is losing its balls a little? If so pull some timing out and try again.
Of course if you have a leaking/stuck open injector thats another matter......
As per above I would look at injectors as a possibility. A dribbly injector/s could cause that. Are you running a higher fuel pressure than standard? Could be forcing fuel through the injectors when parked. Does your oil smell really fuelly??
I would play around with the temperature vs. injection correction table...
when your car is hard to start, pay attention to the water temp logged, then go to that point and try tweak the cranking injection & also the fuel correction for that temp
Cool. Thanks for the feedback guys. The starter motor never seems to struggle. It cranks quite easily, but just takes a while to eventually start. Fuel pressure is standard. The oil doesn't smell fuelly, but I might check it again.
I'll check out the coolant temp correction, etc.
Also if it starts easier with a little throttle applied, I would have a look at the AAC or IACV and give them a test/clean.. there should be some high idle dwell on start up.
I'm not too familiar with your ECU but other ECUs there's an idle dwell which you can adjust which applies a little throttle on startup and dwells a little before dropping to your predefined idle setting.
That's quite a good point about the idle up on startup. I might look into that..
  • 8 years later...
On 4/28/2022 at 11:03 AM, BoostedBarge said:
Sadly I sold the car in 2016. I honestly can't remember if I fixed this problem. I don't recall doing the AAC or IACV. Maybe we tuned it out on the Vipec.
Ah ok thanks
I'm having the exact same problem, cold/hot start like a dream, when its mildly warm she struggle and when start, RICH as fk.
On 28/04/2022 at 11:26 AM, West said:
Ah ok thanks
Your cranking table and prime table needs work.
  • Like 1
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
