Hey folks,
As some of you already know I am leaving for melbourne in a few days once i finalize stuff with our lease.
I just thought i would write a little goodbye. In my time hanging out with the ACT SAU crew i have met some awesome folks and had some awesome times playing break the car and hanging out on fridays. I hope the Vic crew is as easy to get along with.
You guys have been a valuable source of information...and parts.
I will be back up at some point to pick up my car and a few other things once we find our own place down there so i'll try to come out to a meet up if i can.
I wish the best for you all or at least probably most of you..maybe
Take care,
Andy
https://www.sau.com.au/forums/topic/437476-seeya-canberra/
All the best Andy! I will forever remember you through my arse haha :P
All the Best Andy, it was a pleasure sharing a Suburb with you. (Back then) ;)
If you still wanna try out that Airbox, just let me know.
Take the utmost care.
  • Like 1
https://www.sau.com.au/forums/topic/437476-seeya-canberra/#findComment-7167388
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
