Hi Guys, we have fitted a Performance Metalcraft upgraded GTR sump without removing the engine.  It took a (long) day for 2 guys to do on the hoist.  It has raced on every circuit in NSW and a few in Vic since it was done.  I have not seen any oil pressure movement on the data log in over 2 years.  :)
www.performancemetalcraft.com.au
SK, what's the retail on the PMC sump kit? Also how do you reckon it compares to the trust kit (which comes with extension, baffle and new pick-up)?
Cheers,
Richard
Cheers,
Richard
You will have to ask PMC, I really have no idea what they charge.
The Trust kit is very simple, it extends the sump downwards (reduces ground clearance) and has an extended pick up and a cylindrical baffle. It increaaes oil capacity by ~1.25 litres. The PMC sump we use has wings (so it does not reduce ground clearance) out both sides with one way doors and baffles. It does not need an extended pick up. It increases oil capacity by a bit over 2 litres.
In funtion there is really no comparison, a winged and baffled sump is by far a superior solution. Hope that helps :)
just letting you know i know the boys at PMC have been making these sump kits for quite some time a couple of years and have never heard a bad thing about them. CRD highly recomends them as well, i've personally seen seem them fitted to almost stock GTR's to a 1200HP street GTR getting set to malaysia.
we too have one fitted to our GTR as well.
the kit is a work of art go and see leone at PMC down at euston st rydlemere.
same place as hi octane,different people.
great blokes!
  • 7 months later...
Hi all,
Just thought I would provide an update on the Accusump fitted to the car. Its been in for around 6 months now and have had plenty of track days since then.
In that time I have not had any problems with oil pressure on or off the track.
One of the side benefits of the system is that because the canister hold oil under constant pressure, and it releases its oil into the engine when it senses any oil pressure drop, you get oil pressure even before the engine starts.
Turn the ignition to "on", the system senses no oil pressure so it starts releasing oil providing oil pressure for start up. For this reason I leave mine on at all times.
There is a manual switch version usually used in race cars and an electric switch version (the one I am using) which can be turned on and off.
Ultimately I will move to a proper race sump such as SK has advocated, but until then this has been pretty good.
DANOOH,
Originally I looked everywhere. Was going to bring on ein from the States.
Ended up getting it from Performance Wholesale http://www.performancewholesale.com.au/
I don't know who else stocks them, but surely others must.
Cheers
  • 1 year later...
DANOOH,
Cheers
I know this is an old post but besides purchasing the 3qt. Accusump what else is needed to install this on my GTR lump in my S14 silvia? What electric valve unit to use, and mounting kit as well? I will like to order this asap for my build, I don't want anything to give problems after install and have to drop the engine and box.
Edited by TriniGT
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
