For sale is my modified Black 1996 Nissan Skyline R33 Gts-t Series 2
New Oil and Oil filter changed at 152,000 kms.
The timing belt, drive belts, water pump, rear tyres, standard suspension, new coolant, caster bushes, new exhaust manifold studs has been replaced at 144k kms.
Selling this due to needing room at my place, plus need cash.
Km’s – 155,xxx, Manual
Colour – Obsidian Black
Price - $8,900 cash
RWC – Yes, $300
REGO - Yes, till 2014 November (9 Months Rego Left)
Number Plate - ZXC436
Location - Patterson Lakes 3197 Victoria (South-East Suburbs)
Engine No. - RB25164204A
VIN - 6U9000ECR33110397
Modifications.
- Spitfire coil packs
- 3” cat back to 5” tip
- Bosch 040 fuel pump
- Jecks 550cc injectors
- X-treme heavy duty clutch
- R34 high flowed GCG turbo
- Dual core aluminium radiator
- Hybrid Front Mount Intercooler
- G-reddy profec-b boost controller
- Stock ECU remapped with Mines Map
- Sard fuel pressure regulator with gauge
- 19” Lenso Rims, Front on 235/35/19 tyres 98% +
- 19" Lenso Rims, Back on 245/35/19 tyres 98% +
- Alarm & Immobilizer with Remote
- Calibre boost gauge
- Genuine R33 car mats
- EBC pads all around
- R33 GTR Spoiler
- Factory ABS Brakes & HICAS
- Factory Sunroof
All modifications have been less than 15,000 km’s ago.
This car on low boost (10psi) has 193.5 rkw, high boost (18psi) 222.2 rkw, safely.
Cons.
- Few scratches and a mark, that should buff out.
- Heater motor actuator is “ticking” needs a new one or fix the gear inside it
- heater blowing out cool air and air con needs re-gassing.
- Turbo bearings are going, Its ready for a Turbo Upgrade!!
Slap on a GTX3076r or Hypergear SS2/3 Turbo and you'll be hitting 300+ rwkw and be a responsive street monster!
Car runs excellent, just like it should. its going to be sad seeing this go. My loss is your gain.
Pod filter is off and the standard air box is back on due to roadworthy purposes. I didn't have any issues with getting a roadworthy certificate especially due to the exhaust, so i could organise one for you depending on my situation at that moment.
This car is just sitting around on the lawn, and due to having so many cars at the house another reason why i need it gone.
Pretty sure I haven’t missed anything. Any questions, offers, inquiries let me know.
Serious buyers only, No test drives unless I’m in a loving mood =)
Thank you for taking the time to view my ad. I hope you find what you are looking for.
I'm selling this cheap, so throw me an offer as i want it gone for my new toy.
Be upfront, honest and clear.
Text during business hours, or call after 4pm, to arrange a look.
Contact number, 0423 932 035
Cheers,
OJ
post-84763-0-67661000-1390373406_thumb.jpgpost-84763-0-08137600-1390373485_thumb.jpgpost-84763-0-37546000-1390373522_thumb.jpgpost-84763-0-80191700-1390373545_thumb.jpgpost-84763-0-33492400-1390373582_thumb.jpgpost-84763-0-55472200-1390373609_thumb.jpgpost-84763-0-62198800-1390373878_thumb.jpgpost-84763-0-57933100-1390374009_thumb.jpgpost-84763-0-26127700-1390374049_thumb.jpgpost-84763-0-53023000-1390374090_thumb.jpgpost-84763-0-09066600-1390374129_thumb.jpgpost-84763-0-03522900-1390374173_thumb.jpgpost-84763-0-16764700-1390374207_thumb.jpgpost-84763-0-38585000-1390374248_thumb.jpgpost-84763-0-03186900-1390374292_thumb.jpgpost-84763-0-71718600-1390374319_thumb.jpgpost-84763-0-76974600-1390374325_thumb.jpeg
https://www.sau.com.au/forums/topic/437977-vic-wts-96-r33-gtst-skyline/
FRUGAL FRIDAY BUMP $9,000 i will budge for SAU members <3
Get this car before its sold!
if not sold i will get the turbo fixed or upgraded and install a Apexi power fc and sell it above the price that it is listed.
PM, Post, Call or SMS 0423 932 035
regards,
OJ
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
