Hey All,
My names Michael and I used to own a maroon R33 GTST 5 years ago and be fairly active on the forum. I used to attend the meets up on the central coast at maccas all those years ago!
Have recently purchased a black R33 GTST S1. Got it for an absolute steal and its fairly standard and neat and tidy. I plan to modify it slowly over the coming months and keep everyone informed with a few pictures and updates :)
Hope to get involved again in this forum and get out and meet a few more SAU-ers.
Thanks!
https://www.sau.com.au/forums/topic/438081-old-r33-owner-buys-r33-again/
This morning I pulled out the coil packs and did the old tape job to stop misfire in high rpm.
I also discovered a manual boost controller hidden below the air box! The standard solenoid was still int eh engine bay with tubing connected going no where.. So that's a score!
I wound down the boost from 13psi to 10psi and I am getting a much cleaner run through the entire rev range now with no misfires or jerkiness.
Next plans are to re-connect the audio system up and replace the rear speakers that are fu$&ed.
Remember the common issues and fix them :)
- replace coils with OEM or Splitfires
- Replace exhaust manifold studs with uprated toyota ones/oem
- rocker cover gaskets and half moons
- clean your aac and cold start valve
Thanks for the tips.. Actually in the process of buying splitfire coil packs now. 2 out of 6 of my oem coil packs have 1 stripped bolt each so they will be a bitch to get out :(
Also just updating a few other bits:
# replaced the rear speakers that were all cracked, rewired all speakers and head unit/DVD player that was in the car so everything now works.
#bought a second hand 4 ch kicker amp to run all speakers, much better sound now, worth the $50 :D
# found my old his type 1 turbo timer and installed that.. Works perfect, If anyone needs the wiring colour code to the ignition let me know :)
That's about it for now...
I will be doing a full service of all liquids and oils and filters and replacing my coil packs with split fires next weekend :D
Yepo gota love the design of the tail lights...
Installed my apexi el II boost gauge and controller tonight. It is all lit up and working with the controller just need to run the sensor wire through my firewall back to the controller. Boost line is already taped.
Few pictures of my gauge install and my turbo timer install a couple of days ago.. Plus my head unit "tidy up" in the background!
  • 3 weeks later...
welcome back.
loving the progress reports.
Thanks Luke!
Well I swapped over my coil packs... Seems that the coil pack in cylinder 2 had been swimming in coolant at some point in its life. As you can see in the picture by the white crust, there is no evidence now of any coolant leaks after running my car for 1000km then checking on my new yellow jackets.
Its amazing the difference that yellow jackets have made right across the rev range, everything seems so much smoother now and no more misses at any rpm!
In the mean time I also managed to pick up an 18" set of used rims and wheel package! 2 of the rims had some decent gutter rash but was able to sand them back and spray with matt black paint and they look fine now. All 4 have 90% Bridgetsone tyre left on them and they cost me only $200. Bargain....
Pictures:
  • 1 month later...
Had a weekend off work so I took the time to install some of the mods I have had siting in my garage for a while Pictures are attached of the various mods, worth noting I installed everything myself with a mixture of my own knowledge and Google/this forum
· FMIC Kit
· Drivers side seat upgrade
· Conversion Speedo/Cluster kit
· HID low beam and HID Hi beam (8000k colour temp)
· Complete LED conversion of all exterior globs (parkers, all indicator globes, reverse lights, number plate lights etc)
· LED conversion to interior dome light and map lights + I have a blue conversion kit for my Aircon buttons still to be installed.
I took a fair few pictures while installing a lot of these mods which I am happy to do a write up and post for anyone who wants it
Stay tuned in the coming weeks for the following mods:
· Converting the clock plus aircon displays to blue (using acrylic gel) plus replacing the aircon buttons to blue LED
· Interior blue lighting in foot wells when doors open (courtesy lights)
· Installation of new LED indicator units
· Engine bay tidy up with new blue colour hosing and conduit..
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
