Happy Laps - Queensland Raceway 22-03-14
Event:
Description:
A chance to get out on track for a fun cruise and have some om nom noms! Bit of spirited driving is allowed but it is still an event on a race track so a few rules need to be followed (see below). Also if you have not done QR before this is your ticket in to Lakeside.
Queensland Raceway
Date:
Saturday the 22th of March.
Time:
7:00 AM Arrival
Cost:
$35 for members and guests of members
$50 for non members
Please note that this is a per person cost, any passengers etc are required to pay as well.
Requirements:
1. QR have a minimum age of 12 for passengers.
2. No overtaking in the first 2 laps.
3. The overtaking car is responsible for completing the overtaking move safely.
4. Overtaking is only permitted on straights, unless clearly waved passed by the car in front.
5. Overtaking move must be completed well before the end of the straight, and the car being overtaken must be given plenty of room.
6. Cars should not be more than 2 abreast at any point on the track.
7. Be aware of cars around you, in front and behind (and beside when being overtaken).
8. Do not assume that the car in front of you knows you are there.
QR RULES
10. There is to be no racing
11. The straights are speed limited to 120km/h
12. Any car that goes off the track will be pulled off
13. There is not to be more than 1 sec of tyre smoke.
14. There are to be no helmets
15. Vehicles must have current registration and number plates are not to be obscured in anyway
We are moving away from cash on the day so if you are attending please pay several days before the event. Since our bank takes several days to clear and provide details of payments please pay well in advance.
Payment Details:
Name: Skylines Australia Queensland Club
Bank: Westpac
BSB: 034 063
ACC: 354012
PAYMENT REFERENCE: Username&HappyLaps
Attendees:
1. Cadmoon +1
2. Captian Natro PAID
3. Kiwi_Phil +1
4. philsutty
5. AndrewK34 +1 PAID
6. wolfman 101
7. fusion07
8. gts032 +1 PAID
9. Bubbles
10. NW007 +1
11. DYL33
12. cowdy +1
13. Terror
14. Matty95
15 8MYCASH +2
About 15 Evo's to chop.
(45)
I don't think any of the three of you have a hope around qr when the abombs in full stride lol :ninja:
15 laps, average lap time on the clubman or sprint track. Then week see who has a hour in hell :-P
Needs much better tyres, brakes and proper suspension setup + diff.
Mad skillz alone won't get you very far LOL
You have no hope :ninja:
1 flying lap around club man...
Side note what's wrong with my diff/suspenion?
Said it before, your 33 viscous diff is hopelessly unreliable and over time will single leg once the viscous fluid goes past it's use-by date (if they haven't already).
Coilovers alone aren't the answer to track work.
Have you sorted out proper alignment settings for track work? Adjustable arms?
Some of these guys have...
You won't be chopping anyone except for people like me and that's not saying much :P
That car of yours belongs in the sticks and not on the track.
Just so you know I'm just stirring. Pretty rough day at work so far...........
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
