Happy Laps - Queensland Raceway 22-03-14
unless the A in abomb stands for ANGRY35 this statement is false :rolleyes:
Be sooooo keen on this, make it happen Tony !!! :spank:
how bout the VR's looks like Philt sutty is going and I am sure I can get Chris to bring his 35 aswell :nyaanyaa:
Prostitution, its how I got in. :kiss:
I am already starting to sharpen them for you Nick
Will Chris be back from work? I thought there was a chance he would be away.Hope you guys can make it
Are you sure you just didn't get chopped?
I actually think I was lining up the thing next to me rather than the evo... I can't actually remember racing it.
Only things I remember beating me was Scott's gtst, a silver 33 Gtr, a blue Cressida and a Mazda 3 lol
So everything you raced?
Loved troys Mazda 3
^ There it is..
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
