Warning Name
Warning Description
Warning Points
Off-Topic
Any off-topic posts made.
2
Chatting
Any chatting in areas that do not allow chatting (such as the for sale area)
3
Trolling
Attempting to get another member to 'bite' so as to argue with them
5
Trader Rating Abuse
Anybody not using the trader rating system properly
5
Pr0n
Any adult material posted on the forums
7
Personal Attack
Name calling, threatening - anything which is aimed directly at another member with an intent to cause harm
10
Once you reach warning level 20, you will be banned for 14 days
https://www.sau.com.au/forums/topic/43838-warnings/#findComment-895925
how does one know if they've been given a warning? I assume email, but just checking that you do get notified of them. Is there a way to check my personal total/tally of warnings?
...And 99% of users (everyone without any forum authority) have these links to warn and view with no purpose but to be told that they don't have permission. Or is it just so everyone's aware of warnings?
https://www.sau.com.au/forums/topic/43838-warnings/#findComment-896225
I was given a warning in the QLD events section for mentioning another car club/forum.
It wasn't for mentioning another car club/forum Matt...
It was for trolling... See above for the description of trolling...
You've been asked / warned before about this exact thing so don't play dumb...
Happy to talk to you on MSN about it...
https://www.sau.com.au/forums/topic/43838-warnings/#findComment-896508
yes you will be notified by PM if you are warned....its just a system to try and keep things under control....if you accumulate 20 points you get banned automatically for 2 weeks.
Is there a use by date with the warnings? I dont think its totally tragic if you accumulate 20 pts over 18 months to 2 years for example.
https://www.sau.com.au/forums/topic/43838-warnings/#findComment-896963
Ok,
I dont agree it was trolling...
Will have a chat in private mate.
https://www.sau.com.au/forums/topic/43838-warnings/#findComment-898779
Who administrates the administrators ??
Moderators do. We recieve warnings just like the rest of you.
Regarding checking points - you can click "view your warnings" under the Quick Links menu ^ up there.
This is just going to be a fair system for people instead of mods personally PM'ing somebody twice about the same thing etc... just helps us keep up to date with it.
Regarding the links - I will mod that so that only the mods who mod that section can see it.
Thanks - any other q's, post em here.
Christian
https://www.sau.com.au/forums/topic/43838-warnings/#findComment-899149
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
    • Just to get this straight if you turn the splined shaft to the outside, it turns freely but the chain does not move? What happens when you move the chain, does the splined shaft turn? Surely the shaft is snapped, or the chain is seized and it took the teeth off whatever great is behind the steel bracket
    • Good on you for mentioning, that helps as far as other things you might need to check
