I fitted some Defi gauges a little while back with the intention of fitting an oil cooler but never got around to doing so and felt if my temps (with light track work) never got too bad I wouldn't worry with the cooler. But as the factory Nissan temp sensor is M12 x1.25 thread and the defi sensor is 1/8NPT I could never fit the temp sender and effectively had a useless gauge. I spent ages trying to find an adapter through just about every gauge, fitting, performance site and store within Australia and could only come up with suppliers from the UK with shipping worth more than I could justify. I could find adapters that were M12 x 1.50 and M12 x 1.00 but not 1.25 as it's a very odd size.
Finally I found a local supplier on ebay that sells them - http://www.ebay.com.au/itm/Metric-Male-M12x1-25-To-Female-1-8-NPT-Also-Use-For-Pfira03-Fitting-/151195760051?pt=AU_Car_Parts_Accessories&hash=item2333f835b3
All I did was fit an o-ring around the M12 thread that goes into the factory oil temp sensor location to seal it up (thread sealant would do the same but I didn't have any) and thread tape around the Defi sensor. I was a bit worried as the sensor tip did not stick out a great deal from the end of the adapter and not getting a true reading but the adaptor looks to thead in just as far as the factory sender and after taking my car for a run it seemed to work near spot on.
The temps warmed up relatively similar and after a good freeway run with 30degree ambient temps in Adelaide the oil temp was within 5 deg C to the coolant temp which is what I expected to see.
Yeah I have a gtt and see link to photo of the sensors location on the oil filter housing with the adaptor in place, the hot engine bay made it hard to get in closer lol
http://www.use.com/supersize.pl?set=3703df3839032c6a08eb
Edit: Sorry, you said it was M12 thread, I thought it might have been the stock oil pressure sensor but with that thread I dont think it can be, pretty sure Nissan used the same 1/8 sensor for all Skylines
Edited by 89CAL
Yeah the oil pressure is 1/8th NPT but the temp is M12 x1.25, Blitz make a similar product but as I said rather buy Australian if possible
http://www.fqperformance.com/shop/product_info.php?manufacturers_id=20&products_id=876&osCsid=ezhimmjjeyco
There is an easy way for rb 20
Dunno if rb25 is the same
I decided that the sensor is going to get pretty good accuracy, but take an extra 2 or 3 seconds for the temp to get there.
Fluids are good at transferring heat. Even though its not in the stream of oil, it works very well.
Edited by D.I.Y. Mik
I remote mounted my 2 oil pressure sensors. Just used a -4 braided line (I think it was -4 or -3) and put a fitting in the block and a T piece and the 2 sensors up the top. Pretty much the same as above, but remote mounting it for easier access. Probably not as good for oil temp, but works for oil pressure
Yeah havent had any problems with strange oil pressure readings. They are pretty much spot on where I would expect them to be.
Originally was going to just tee it off the block but this seemed smarter in case anything ever went wrong its so easy to fix :)
I've painted everything since then so its all black now bar the braided line, can just see it in this photo, it blends in pretty well now
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
