Put the gfb bleeder on and diled it in. Not to much of a difference but there is definantly more pickup in the mid to high revs
Other than that I don't think there is anything else
In a few weeks I should be putting the rear subframe bushes in I just have to get greggo (sick_31) to help me out because he wants to be there hahah
Tomorrow arvo or Saturday arvo I might give it a good wash and clean the inside of it
Also try and attack the disgusting wheels and bring some shine back into them
Pics will follow that one
  • Replies 293
In a few weeks I should be putting the rear subframe bushes in I just have to get greggo (sick_r31) to help me out because he wants to be there hahah
Edited the tag for sick_r31
While I do it I maybe swap to another 25 and cruise around on that while I do up my current one
But no will be staying with 25
I have also lined up new parts just need cash
Let's just say it will be very cheap for me to do what I'm planing because no labour charge and it should get me some good gains
Should cost about 2grand in parts (not including parts or machining work for engine)
I liked your old pan better, only because of a certain car from my past that had the mods you planned and was the most fun and reliable skyline I have seen. This new plan at the very least should be interesting though!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
