Put the gfb bleeder on and diled it in. Not to much of a difference but there is definantly more pickup in the mid to high revs
Other than that I don't think there is anything else
In a few weeks I should be putting the rear subframe bushes in I just have to get greggo (sick_31) to help me out because he wants to be there hahah
Tomorrow arvo or Saturday arvo I might give it a good wash and clean the inside of it
Also try and attack the disgusting wheels and bring some shine back into them
Pics will follow that one
  • Replies 293
In a few weeks I should be putting the rear subframe bushes in I just have to get greggo (sick_r31) to help me out because he wants to be there hahah
Edited the tag for sick_r31
While I do it I maybe swap to another 25 and cruise around on that while I do up my current one
But no will be staying with 25
I have also lined up new parts just need cash
Let's just say it will be very cheap for me to do what I'm planing because no labour charge and it should get me some good gains
Should cost about 2grand in parts (not including parts or machining work for engine)
I liked your old pan better, only because of a certain car from my past that had the mods you planned and was the most fun and reliable skyline I have seen. This new plan at the very least should be interesting though!
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
