Hey Ben, Congrats man thats very nice power !! RB20s still rock ! 12 years on
One suggestion though, turn boost up a little higher say 1.3 - 1.4 bar.
On mine from 1.2 to 1.4bar really starts pulling hard @ 1.4.
cant wait to put the Rb26 cams and pulleys. Gotta do the clutch first tho..
yeah i plan to get it on the dyno again next week before WSID on wed night, I might just do one power run on high boost, but i get a little scared, this is my everyday driver so i need it to run reliably :(
But like i have said before, i need to have a dyno print-out with over 300rwhp and my name on it. just so i can say i have over 300hp
what does everyone else think about running around 1.4 bar? on a stock RB20 with std headgasket? i was considering running the 1.2bar when i race, but for everyday i only run between 0.8 and 1.1bar.
MRK25T you need to let it open up, these turbos are designed to run highish boost to reach their efficiency peak @ 1.3 - 1.4 bar...
theres a shitload of power to be had from 1.0 - 1.4 bar...
The next owner can boost it more, I couldnt afford a new engine if it blew so got it tuned acordingly. The tuner at Procar did a great job with the car, it is very smooth. Notice how straight he got the AFR.
They are a great turbo, much better than my high flowed standard turbo.
yeah the A/F ratio is awesome on yours! i need to get mine like that.
was it Paul who tuned your car? he was very helpful and knows his stuff, he showed me some stuff on a 900hp NA V8 he recently built! imagine having an NA 900hp engine!
I really need to invest in a PFC! anyone got one cheap for me? hehe
yours will pull some awesome numbers once the boost is in mark.
No, a specialist tuner came in to do my tuning at Procar.
WHo was the tuner mark? Dont be shy.
Paul from Procar will tell you. He doesnt do any joe shmoe off the street. He tunes the car only if you are sitting in the car with him the whole time and explains everything. I dont know cars, but I did a fair few units of physics in my science degree and it all made sense to me.
The car is no longer mine, sold it this afternoon.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
