I just asked the question. coz my car had a label of unleaded. not sure what rating it was.
Plus i have read somewhere that E85 mixture is ok for the car too.
But i do agree with people here. i get more mileage on my cars when its on 98ron. runs better goes longer.
According to the FSM, the ECU switches to a 'knock map' when it detects knocking. But I have never observed it or tried to trigger it.
Yes, but there seems to be this perception that the ECU "removes" timing when it detects knock on the fly.
I've never seen any evidence of it, when I played around with Uprev and set the knock map up, it is quite simply just another Ign timing table to set say 20 points lower than the standard table.
E85 requires a custom dyno tune, complete with a marginally larger set of injectors.
As above, you CANNOT dump a tank in and expect the car to run ok.
  • Like 1
Yeah good luck with all that.
Its amazing what other kids can tell you in the sand pit these days
Edited by Howaitonaito
sometimes its just good to know...hehe Thanks for the info guys!!!
fyi: my 350GT has never tasted petrol below 98ron in my care.
Yes, i believe that is correct, it is just a 2nd map with a fairly heavy timing retard (and fuel mix richen).
The FSM specifically says the knock sensor is a 'last resort safety device' and is not a tuning device, so when knock occurs the ECU just smashes back the timing to try to prevent damage, it was not intended to 'adjust' to low octane fuels.
And the other false perception is the ECU uses the knock sensor to advance the timing for higher octane fuels.
the only ECU I know that actually uses multiple knock sensors to 'tune' the timing is the newer WRX STI ECU.
Well the article i read was from cars guide and not specifically talking bout our skylines but were talking about modern cars. Im guess anything over year 2000 is a modern car.
That is why there are forums like this to ask questions and get answers from experienced owners.
Thanks for your statement though.
If that place you read that awesome piece of factual *cough* information also said the the boogie man exists would you believe them.
No.
Has anyone used e10 91 on their v35s?
Our cars can use 91ron but not sure if with E10 would work.
read me
http://www.unitedpetroleum.com.au/united/fuel/unleaded-e10
do a little homework ,...e10 is 95 octane...i dont know why the misconception I hear so often, I guess because its cheap eveyone thinks its low octane...Its 95 octane at cheaper cost....and yes it should be fine to run...run it in my 04 honda all the time...may get 50kms less a tank but at least i know my injectors are clean...
No way is e85 ok for your car.
some cars with high compression rates can run it ok., I know guys in USA have tested it in Hondas and it runs good and pulls harder faster than petrol.....
that said
Its still not a very good idea but if it were an emergency you can get away with it
You would be surprised how much e85 you can put in the tank before the ecu calls it quits and throws a code. Remember the o2 sensors in these modern cars are very good at re-calculating short term fuel trims. I have heard 50% is usually ok.
But they run to AFR... Not lambda.
E85 and 98 have different stoich ratios. Which the O2 sensor can't take into account. It's fixed on 14.7- petrol.
Both have a lambda of 1 ( lambda is just the indication of the best or most efficient ratio). So you might then tune petrol to 11.5afr, however that isn't equal to the same ratio when using e85
As the sensor reads lambda it automatically compensates for different fuels. I tune e85 to 14.7:1 on my gauge and it is just as stoich as a petrol tune. (just remember, e85 isn't 100% ethanol anyway.)
United 100 octane is garbage. its not really 100octane since it uses 10% e10 to boost the octane rating. been using it until i got my car uprev tuned and now running shell 98, much better
you are a moron. octane is octane. it's a way of measuring any fuel. LPG has an octane rating too. E85 is ~105-110 octane depending on the exact blend.
United's E100 works really well. In my R33 it was noticeably better than 98RON.
Yeh, it's 100 octane ;) lol
I get poor economy using it compared to normal 98ron fuel.
Up to 50% worse km per litre (ie 250kms for 60L of United 100 compared to ~370kms with Mobil 98)
50% worse? It's either your right foot or something is seriously out of whack with your car. I ran United E100 all the time and it made almost no difference to my fuel usage.
O2 sensors work by sensing lambda, not AFR. They measure the ratio of oxygen in the exhaust gas to oxygen in the air, and their output changes around lambda 1 regardless of fuel. The O2 sensor doesn't know you've squirted 14.7:1 worth of fuel into the motor, it doesn't care. All it cares about is how much oxygen is left in the exhaust gases and that is lambda.
  • Like 1
Ok, so let me try to understand this.
Hypothetically, you can fill up your stock as a rock car with e85, drive it around on closed loop, and have a e85 lambda of 1?
What is the e85 afr equilivent of 14.7?
No, because the stock ecu will only add or subtract around 10% of the fuel. Anything outside that range will trigger the MIL as the ecu will know something is seriously wrong.
Ethanol stoich is 9:1 I think. Not sure what e85 would be as I have never needed to know.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
