About 5m at a guess. :P
It would depend if the inside of the muffler is stainless, or if it is just the body. Exhaust gas is very corrosive and will rust out any unprotected steel in no time.
Are you looking S/H or new? Perhaps someone could make you a proper stainless system locally rather than importing? ;)
  • Like 1
Yes the S/S lasts forever.
An interesting sideline is that where any sensor screws in, it's best not to use an aluminium washer.
In the end result of a chemical reaction, the aluminium loses and corrodes (albeit slowly); although there are different grades of S/S and also of aluminium, usually designated by 3 digit numbers.
You'd think that exhaust gas is a reducing environment due to carbon monoxide and unburnt HC, mild steel exhausts would normally last ages. But then again, there's also NOx produced, with combustion water. So that's oxidative.
I've seen the light with regards to stainless.
    • I am well aware as I did rant at him to buy a MX5, buy the 2.5 before he DIY'ed it, etc as well as do things to the holden. He will obtain a ND. It's the best of both worlds. They look great in person, definitely the best looking one. Just a matter of time now.
    • Remember this is the same person who said he’d never own an nc
    • ouch! how is the car now?I had sold my gtr but have been looking into some on trademe and a 260RS but I wouldnt be keen on any repairs needed on them
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
