On a BNR34
Face #2 20x10.5 +11
2 bodyguards hahaaaa
Simon's probably right; but I wasn't sure about clearance of the suspension on a BCNR33.
God_speed has a set of 20" F/S
The width is sweet. however, I reckon you will get poke with a +11 offset.
I have 10.5 +15 and if I were to add a extra 4mm out I would be just outside the guard. I'm talking 1-2mm outside. You'd then have to roll guards. otherwise I think you will be partying in scrub city. Ain't nobody got time for that
34's different. They take more coz they even fatter.
hmm.. are you quite sure about that? how would the fitment compare to my;
- Buddy Club P1 QF Racing, 18x10 +22
- Blitz Techno Speed Z1, 18x10 +22
well if you only go by width and offset then
you are increasing it 0.5" which equates to 0.25" + the stronger offset of 11mm which equals a grand move of
17mm outward movement.
So go and take a ruler to your car and see if you have close to 2 cm room
the wheels look great, but i think the extra 2cm is just a bit too much and to spend too much cash for extra set of wheels.
looks l will just go for the OKADA PROJECTS Plasma Direct Coil Packs
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
