Hi guys last night I was driving with the Mrs to her house, HWY patrol past me in the other direction and saw me so did a U-Turn, I was right around the corner from her house and I pulled into her driveway, with no sirens or flashing lights they pull in behind me, breath tested and drug tested me and all was clear, then they proceeded to pop my bonnet, I got defected for BOV, bald tyres and apparently too low although the car is 125mm off the floor at the lowest point but I was parked on a shitty slope type surface her driveway.
Now I got a yellow sticker and can't drive it after 4:15pm tomorrow and have a full inspection at botany HVIS.
On the defect paper it states.
1. Vehicle ground clearance - to comply.
2. Aftermarket exhaust - to comply.
3. Check legality & performance of vehicle braking system - to comply.
4. Check legality & performance of vehicle suspension system - to comply.
5. Check legality & performance of all (4) wheels and tyres - to comply.
6. Blow off valve fitted - to comply.
Major Defect and yellow label.
The defect must be cleared by a/at full inspection ticked and light vehicle ticked, also Authorised Heavy Vehicle Inspection Station (HVIS) ticked.
Questions that I need help with please, and yes I have searched but it looks like I'm completely hopeless with that.
1. Will my car pass with Tien Coilovers which I can only adjust the spring load on and not height.
2. Will it pass with the factory tinted rear windows as they brought that up aswell.
3. On my compliance Engineers Certificate wheel/tyre size is 225/45/17 front and rear 235/45/17, will I pass with fronts 225/40/18 and rear 255/35/18 - they didn't complain about wheel size yesterday.
4. Will I pass with my pod filter although it has an aluminium box.
5. Front mount intercooler although it's tucked in behind my bar no extrusions etc.
6. I have a 3inch full exhaust with cat, and exas evo tune catback, will that also pass or will it be too loud.
7. If I just take my aftermarket wing off and put stickers over the wing holes will that also pass.
Thank you for any help in advance and I'm so sorry if this has been already covered, most likely it has but like I said forgive me please I'm hopeless with the search function, thanks.
https://www.sau.com.au/forums/topic/439211-defected-and-questions/
I got nothing important to commit to the topic but I got a return question - can't you just get it cleared by a mechanic who does blue slips or do they actually require you to drive to their inspection centre?
I wish that was the case, unfortunately the popo ticked the HVIS which is the rta heavy vehicle inspection station, where they normally love to rape people.
Good luck dude - it sucks sometimes how they target us as opposed to real crims!
Yeah I know, I even told them, I pointed out this Ford Laser 80's model to them across the road and told them that they should really be pulling those cars over and not us as we would check our brakes, safety system etc, plus on top have abs, stability control etc, the laser across the road is a nightmare, oil leaks everywhere, brakes squeal like a pig getting tortured, bloke barely stops, scariest part is that the fuel leaks out of the fuel cap/flap on a hot day lol.
Theo Syriopoulos head of SYRIOPS Engineers delivered a talk alongside myself 3 months ago at Canterbury.
He does Engineering Certificates and assists to clear defects.
For starters, you'll need to get replacement tyres and a plumb-back, but you can call him on 0402651759 or 02-95336737 to get some expert advice.
He's stationed at 172 Belmore Rd North Riverwood
  • Like 1
Do you have to go to a certain workshop or can you choose where to go? That will make the biggest difference in this situation.
I learnt this recently. I got done for alot more than what you did. We went back to stock on most of what I got done for, and come blue slip day the bloke told me he doesnt mind passing me even if it was the same as when I was defected...
Mine was ticked AUVIS, it is strange you got HEAVY vehicle inspection station ticked...
That's why I was confused - skyline isn't a heavy vehicle... Should just be an AUVIS defect. :S
Unfortunatly it used to be like that, rules have changed, they can follow you into your driveway as long as they saw you 50+ meters away from you're home or any private property, although if you're at your residential address they can't breath test you or drug test you but if you're on someone elses property they can.
Quick update:
Screamer pipe is off - and I can say I'm glad lol, I think I'm getting too old, it actually started to get annoying.
Blow off valve done.
Gonna do a full service tomorrow just in case they do an emissions test and it will help with that a little - new spark plugs, fresh oil etc.
Ordered the tyres and am going tomorrow to get them fitted.
Booked for Thursday so I'll see how I go and if it doesn't pass I will know exactly what I need to do, I will keep use updated, thanks.
Edited by MrRx7s3
Sounds like they ticked the wrong box mate, defects cleared, lol nah seriously wasting time going to a heavy vehicle station, I would call the botany station directly and find out if they do light vehicle inspections also. No point heavy vehicle inspectors checking your car, they would know what to look for, and personal experience, I've used a mechanic shop to clear defects for my gtr, but the same shop also cleared defects on the work truck I drove for the company I worked for. If the f**kup the paper work, it should simply void the defect/infringement notice. If we f**kup and forget to carry or licence we cop a fine, for something we possess. Shit gets my blood boiling. I'll leave it there. All the best
Unfortunantly again, heavy vehicle inspection is what they call the (pits), the strictest inspection, I did call today and made an appointment and they did confirm that yes they do defects, again you gotta love the Australian law brother, they can make the rules as they please and in what mood their in, and if they did do something wrong they have covered their arses by calling it a simple typographical error and the defect still applies - on my previous car I got defected and they wrote down a completely different make/model of car and I tried fighting about it but all I got back is it was human error a typographical error, it's ok I'm happy, got a call from my lawyer after he spoke to the commissioner today because I called him to come down as he lives around the corner when I got pulled over, she is in some trouble as since September 2012 they aren't allowed to show their tattoos, they have to cover them with long sleeve shirts etc, she on the other hand had a full sleeve tattoo uncovered - don't get me wrong I have nothing against tattoo's, I love them, but she wants to be an arsehole well payback is a biatch, thanks.
Not too sure on that one, I really don't believe so though, although the bastards might say something along the lines of power to weight or strength or come up with some kind of crap, I will find out in the morning for you and let you know, thanks.
So he is able to provide engineering certificates? I am looking for advice for my build and an engineering certificate for all my modifications..
Edited by Tonba
Lancers dont need engineering! :P
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
