I hate to spam the crap out of this thread with self promotion but....
We can now let people know that Koenigsegg Australia is on board as a sponsor of the Hughes Charity Car Show and the owner will be bringing his black 2005 CCR down to Kelso Oval on Sunday 6th!
If you are not sure what this 800+ HP Swedish Hypercar looks like:
Hey guys,
Just wanted to share the great article we got in today's paper with you all
Just to remind you that we are still taking entries, and entry forms can be found here
Even if you are paying on the day i need an entry form back from you asap!
@ djvoodoo: Sounds good mate!
Also just reminding people that I need entry forms back asap! You can pay on the day if you like but I need the forms back before the day.
I look forward to entering a whole lot of skylines into the show and shine!
FYI, anyone who was planning on checking this out this weekend, looks like it has been postponed.
From their website:
IMPORTANT:
SADLY WE HAVE HAD TO POSTPONE THE HUGHES CHARITY CAR SHOW DUE TO RAIN WE WILL BE BACK IN CONTACT WITH ENTRANTS EARLY NEXT WEEK WITH THE NEW DATE
Yes, I was concerned about Rain Vs Highly Polished Hardware
On the other hand, i imagine it would have made for a once in a life time opportunity to see a koenigsegg get bogged in a muddy park :P
Hey guys, sorry for being a bit quiet we got totally rained out on the weekend and we were all madly ringing entrants and trying to sort out a new date for the show!
So we can now confirm that the show will now be held on SUNDAY 22nd JUNE @ Kelso Oval!
If someone can tell me how to change the name of this thread to reflect the new date that would be awesome!
  • 1 month later...
Hey guys, has been a bit quiet in here!
Just letting you all know that we are still taking entries for the 22nd of June and entry forms can be found at www.hughescarshow.com
We have some great side shows lined up for the day including: a 1/4 scale jet powered dragster that runs 200MPH+ and has it's own parachute, a massive slot car track with scale V8 super cars, RestoreFX doing a demo of their great products and much more!
And don't forget it is for a great cause!
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
