Hi,
Have a whole bunch of spares for 180sx inc Type X, S15 and R33;
including a 180sx Type X shell.
Located SE Suburbs VIC
180sx Type X Spares:
Type X Front Seats $300
Apexi Pod with S13 SR20DET Adaptor and AFM $200
Type X Cluster - 16x,xxx KM + Cluster Surround $200
Type X Rear Parcel Shelf $80
Type X Roof lining $50
Air Con Condensor and Pump with lines $120
Type X genuine Front Lip $325
SR20DET S13 Clutch Fan $60
180sx BM44 Brake Master Cylinder (ABS) $90
Type X Shell - Rear end damage, would suit drift/track build $1000
180sx 'Type S' Spares:
Type S Steering Wheel $30
Type S Door Cards $100
Weathershields $100
Type S Taillights and Rear Garnish $350
Type S Front Bar and Pods $300
180sx Stock Dump + Front Pipe $20
Glove Box $10
2x Centre Console $30ea
SMIC + Crossover pipe, BOV, Air Guide $150
T25G - 130,xxx KM $150
S13 SR20DET Fuel Rail + OEM Fuel Rail and Injectors $130
Type S Carpet $80
Type S Seatbelts $100
SR20DET E5 OEM 180sx ECU $150
Random Spare Parts:
Sard 555cc S13 SR20DET Injectors + new plugs $400
4pt Harness $150
Stock S15 wheels + tyres $300
2x Space savers $10ea
Enkei RP01 with Bridgestone RE001 Tyres (16x7 +32, 16x8 +38 - 4x114.4) $800
Work XT7's (17x8 +25, 17x9 +38 - 4x114.3) $1000
Nissan Turbosmart Plumback BOV and Adaptor (NEW) $250
Ford BA 12" Dual Thermo Fans (NEW in box) $200
R33 Clutch Fan $60
R33 Skyline Slotted Rear Rotors (NEW in boxes - RDA908S) $180pair
Z33 350Z Front Rotors (NEW in boxes - RDA7685S) $220pair
Apexi Twin Chamber BOV $50
S13 180sx 3" Catback exhaust + 3" Cat $300
Bride Drivers Seat Rails (Super Low, RH, Part: LS.B.10Z - S13, S14, S15) $200
S15 Nismo R Tune Coilovers - $600
Can provide more images on request.
Contact - Jarrad
0432 790 508
Edited by jdniss
https://www.sau.com.au/forums/topic/439345-180sx-s15-and-r33-spares/
  • 1 month later...
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
