if you put one on your sump plug,
wouldnt it be the same as having a magnetic sump plug?
i perosnally dont have one (cant seem to find one for a skyline)
but my mate has one in his rx7 and when he pulls it out its just your normal plug, with a extended stick on the inside and this is where all the metal stuff sticks to
If you stick the magnet to the drain plug, will it catch all the metal bits? Obviously it will catch whatever comes near it, but metal has to travel down through the engine first, where it may get stuck.
What i was trying to say was: Does all oil flow directly past the sump plug, so as to get caught by the magnet? By placing the magnet on the filter, you are guaranteed to catch everything, because all oil has to flow through the filter - it's pumped through it. This is not necessarily the case with the sump plug...?
Greg, over time the entire body of oil will come in contact with the sump plug, because its constantly sloshing and moving around. It wont have the same surface area as a filter obviously, but a magnetic sump plug does work!
Makes me wonder...
If the outer jacket of the oil filter is the intake side (which I think is correct), then this magnet will catch the particles before the filter has a chance to do its job. Also, when you turn the engine off some metallic particles will probably fall off the surface of the oil filter and cling to the magnet. So big deal, you don't really know how much benefit you're getting. Probably the same as changing the filter and oil more often.
If the outer jacket is actually the exit side then the magnet's actually trying to pull metal particles through the filter... whoops!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
