So when I bought this car, the guy was saying that included in the price was these none standard wheels. Fair enough, they do look better than the stock standard ones I thought and I went with it. But are these even OEM 350GT wheels?
This is what I found for stock wheels for the 350GT
This is what I have
So by the looks of it, the couple only had 18" and 19" wheels, the sedan had 16", 17" and 18".
They look decent but why are they only 17"? They appear to be genuine Nissan, maybe from a Maxima or something? I cant find them anywhere.
I'll have to check but I think they are 215 front 235 rear. Seems like a downgrade and a rippoff.
https://www.sau.com.au/forums/topic/440299-what-are-these-wheels/
they look a bit like J32 Maxima rims, but not quite the same.
it is easy enough to put the 'Nissan' cap on just about any rim.
Any S2 V35 (sedan or coupe) will require a minimum of 17in rims as they have larger stock brakes than the S1.
Edited by sonicii
take off one of the wheels & check the back of the spokes
if it's genuine nissan it should have Nissan stamping on the back of the spokes, or even Enkei.
Enkei made the stock wheels for v36 so I'm assuming v35 should be same?
The back wheels look tiny in those rear guards though :/
Thanks Howaitonaito, I guess they are genuine Nissan afterall.
And yeah Yo-Yo I agree, going to spend a little on a new set and will be putting on a set of spacers like nightcrawler has said.
Not sure if I want to go with 18" or 19"
Mint set painted in like a gunmetel on ebay for 850
mmmm, those look awesome, the darker colour might match up better with a white car. I am probably going to paint my grille black too.
Thanks for the heads up
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
