I have had this car for about 18 months and have done my best to make it into a well rounded package. Nothing has been overlooked when building it and i have used top quality parts throughout. Unfortunately due to the nature of my work I just dont get to drive it, which is why it's now up for sale. The engine and turbo have done less than 5000 km's since the build and the gearbox has about 1000 km's on it. There's nothing left to do, just jump in and drive away. The perfect track day weapon, drifter, drag racer or street cruiser. The price is negotiable to a small extent, you couldn't buy all the parts alone for the price I'm asking. Located in Adelaide, north eastern suburbs. I can be contacted here, but probably best to call 0431 297 568. Asking price is $17,000
1996 180SX Type X
Body: Full factory type X kit including spoiler, rear valance and carbon fibre rear garnish. GTR N1 front bumper vents, Re-sprayed in Subaru metalic silver, genuine electric ganador mirrors, Raybrig multi-reflector headlights,
Wheels: Rays Volk TE73 17x9 +22 in bronze
Suspension: Tien HR coilovers, GK-Tech front caster rods, tie rod ends, GK-Tech rear traction rods, Cusco camber arms
Brakes: S14 5 stud hub conversion, R33 GTR brembo calipers with slotted disks, R33 handbrake set up
Engine: ACL bearings, ARP head studs, metal head gasket, Eagle con rods, CP pistons, re-con head, Tomei Poncams, GK-Tech rocker arm stoppers, custom painted rocker cover, Nismo 740cc injectors, Bosch 044 in tank fuel pump, Garret 2871R turbocharger, AM Performance stainless steel exhaust manifold, intercooler pipes, intake pipe, dump pipe and 3" exhaust with dual titanium tips all ceramic coated, large front mount intercooler, Koyo aluminium radiator, GK-Tech clutch fan, GK-Tech radiator air diversion panel, Nisstune engine management, Greddy extended sump, GK-Tech sump guard, freshly rebuilt gearbox, NPC performance clutch, lightened flywheel, Cusco 18 row oil cooler, remote oil filter re-locator, titanium oil catch can
Power: 247KW at the wheels on the first tune at 22 psi. Dyno sheets can be prrovided. Re-tuned to run on E85 fuel this package would be capable of 300kw at the wheels.
Interior: Full Type X interior, black suede re-t trim roof, window tint, Nismo 330F steering wheel, Works Bell rapfix quick release hub and short boss, Defi BF series guages (boost, oil temp, oil pressure, water temp), Oddesy battery mountred in the boot, Alpine IVE-W350ABT double din head unit, American Audio 1300W 5 channel amplifier, Kicker KS6.2 6" split speakers, Eclipse 10" slimline subwoofer in box
https://www.sau.com.au/forums/topic/440304-adl-1996-180sx-type-x/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
