Today driving home I was admiring my car on how clean it is. I then started thinking about how the people before me really took care of it. But how many people have owned this car? Is there a way to track down ownership of a Japanese car? What did the odometer say when the car came across? I don't know the answer since all documents of importation are lost between owner(s). What I know about the cars history is little to none. At one point, the speedometer was converted from KMH to MPH. So that actual odometer reading couldn't be accurate. When I was purchasing the car, I saw it with what I thought it to be 123,000 KM but when it could be something so much more. Here in the U.S. we use CarFax.com that tells all reported accidents, ownership transfer, odometer readings, and any red flags. Does anyone know of a such site for Japan or know how to obtain any history of a Japanese car prior of importation? This is straight curiosity for me and is by no means urgent. Thanks
https://www.sau.com.au/forums/topic/440408-curiousty-of-history/
Once when I bought my wife a 523i we remarked how well it had been cared for.
I looked at the log book and then the name of the original owner.
Then I called the lady to compliment her.
She was taken aback but was gracious enough.
The irony was that the dealer who sold it to us got stung by A Current Affair for tampering with odometers and shamed accordingly. He was the owner of Cars Autohaus and then Pennant Hills Ford.
2 stories there,sorry ;)
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
