hey guys just need advice on how to polish cam cover plus valley covers i have paint stripped it wet and dry from 400,600,800,1000,1500,2000,2500 and 3000 and then used autosol but it looks pretty dull haven't got mirror finish any help would be nice cheers joe
https://www.sau.com.au/forums/topic/440514-polishing-aluminium-need-help/
You need power for the next level of shine. Get a die grinder and you can then buy el cheapo polishing kits from Supercheap that you can put in the die grinder check and polish the life out of it. The kits even come with different polishing compounds to match the different polishing pads to go through the different levels of shine.
Bugger the Die grinder you will be there for weeks... bunnings have small polishing kits in the toil section...I'd recommend just getting buffing wheels foe your drill there is a 2 wheel kit, one is course and one is a finishing buff...try to get one that doesn thave a huge bolt through the middle as these tend to scratch easily and fall apart..Also the paste style polishing kits are horrible to work with, (I think the brand is Joscal iirc )instead go to Autobahn...look for a product called Purple...use this with the buffing wheel on your drill, It will come up pretty good. ;)
Josco is what your thinking of.
I find its the most powerful
You can polish too much if your not careful, then its not flat anymore and looks like chrome plastic.
oops
Oh.. and a clearcoat, never polish again.
Edited by D.I.Y. Mik
Hey guys,
My DIY suggestion would be to go down to 400, maybe 600, grit then use a bench grinder with pigtail on it so you can spin on a stitched buffing wheel and go nuts with a grey or red/brown compound till you get an even shiny finish everywhere.
Clean that down with a few clean rags and kero/WD40/metho/petrol.
Go again with a loose mop buffing wheel and white compound for a nice finish. Don't get the aluminium too hot (keep moving the work piece) otherwise the white will streak. Streaks can be easily remove with kero, just wipe them off and go again.
I suggest wearing gloves to stop your hands from burning from the heat and ALWAYS wear safety glasses. A dust mask is suggested.
If I can help further, lemme know. I spent a few years running my own metal polishing business and worked on a few show winners here and there.
Mark :)
Heya GTR,
I used a Dremel tool and made my own polishing bits.
To DIY, you can use some balsa wood (soft craft wood) and some 400/600 grit wrapped around it to polish the tight stuff, then you can squeeze a small buffer in there, or go at it with some Autosol polishing paste on a rag wrapped around a balsa wood stick. It really depends how far you want to go.
Here's a 12a twin dizzy timing cover for a well known RX3 I did a while back:
And a gearbox for the 2005 Summernats Grand Champion:
Both had some intricate work to get in the tight corners.
I've done shedloads of 20B and 13B REW intake plenums and polished between the lettering to make it look nice, it just takes time and an eye for detail.
Mark :)
mark that looks bloody awesome thanks for all ur tips if i have any more problem i know who im calling :P
can i also use brown compound white then red or brown white then green compound
Edited by gtr0321994
Thanks GTR,
The colours are similar across most brands.
GENERALLY you go from darker to lighter colours. The lighter the colour, the finer the compound. There's exceptions to this, but as a DIY rule of thumb, it'll get you over the line
The JOSCO kits from Bunnings etc work ok for the DIY'er.
Just remember, hardest to softest, darkest to lightest and NEVER mix compounds. So your sewn mop (hard buff) should be used to grey/brown/red compound and your loose mop (calico/soft) should only be used with the white/blue compound.
Kerosene is the best cutting compound for aluminium, it's also great to clean the left over compound off your job.
Many people like to polish down to 2000+ grit. This isn't necessary if you intend to hit the part with a sewn/hard buff. The compound will glide over the top of the fine 2000 grit scratches and won;t do much. The compound needs something to bite into to work, so 400-600 grit should be fine with a bit of extra time on the buff.
With my hardcore setup, I'd never go finer than 400 grit and sometimes I'd even bypass the roughing stage all together and hit the buff straight from cast (obviously a little further advanced mop and compound selection with a 1kw buffing motor).
Any questions, just ask away.
Mark :)
Oh yeah, I suggest dipping the emery paper in a cutting compound regularly so the paper doesn't become loaded up with swarf. It'll work faster and look better as well as using less emery paper for the same job.
As mentioned, kero is the best cutting compound, but water will work OK.
When moving to a finer grit, change the direction of polishing by 90deg. If you keep polishing in the same direction when you move to a finer grit, it'll take longer and the result is not as good (you're polishing along the previous grooves/valleys, you want to cut across them)
Mark :)
Love it when a pro gives us his hard earned knowledge.
Those bits look amazing, now i want to polish everything.
Thanks Mark
SAU is great for this stuff.
Hey Mark, what do you think of clearcoating it?
Does it last? It seems to look ok on the bits ive done.
Heya DIY :)
Polishing everything sucks.
I polished everything in my RX3 enginebay back in the day and I hated hand polishing it every few weekends and I did it full time! Each to their own ;)
There's no clear coat on the planet I was happy to use.
Every one of them will either wreck the finish (introduce orange peel or dull) or not stick to the highly polished surface.
The most obvious choices are:
Powder coat. Is too thick (dulls and orange peel)
2K paint. Won't stick and will brown with engine heat.
Best to hand polish it every few weekends with Mothers or Meguiars polish. Autosol works great for chrome and stainless but it's too course for perfectly polished aluminium (although great to remove water marks and light corrosion).
Mark :)
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
