Harro,
Item 1: NPC Carbotic Clutch Disc
Price: $300
Comments:
  • Thought my clutch died, turns out my clutch fork was fractured & my bearing carrier was the incorrect
  • Scott from Western Clutch measured it and said it's about 0.04mm worn only, near new
  • Disc is under 2 years old, has had about under 14000 km street driving and 3x track days, car makes under 200kW
Reason for Sale: Downgrade to a lighter disc that's more drivable for the street
Item 2: Toshi Remapped R33 Series 2 ECU
Price: $300
Comments:
  • Difference is day and night, others will understand
  • AFRs super safe, sits about 11.7~11.8 all the way at 0.9bar - has been taken to the track many times
  • Tuned for full exhaust, front mount, healthy fuel pump, and boost at 0.9 bar, ~13psi
  • Please check your base timing, set it at exactly 15 on idle with the TPS disconnected
  • Will install and check your base timing for free if you're local
Reason for Sale: New turbo & ECU
Item 3: Stock R33 Series II GTS-t Manual Radiator
Price: $50
Comments:
  • Decent condition
  • Doesn't appear clogged or anything
Reason for Sale: hast tag becauseracecar lol
Item 4: Stock R33 Series II Front and Rear anti roll bars / sway bars with bushing & brackets
Price: $80
Comments:
  • Decent condition
  • No cracked bushing
Link to other stuff for sale too:
http://www.skylinesaustralia.com/forums/topic/433062-fs-syd-r33-gts-t-part-brake-pads-subframe-collars-wheels-gauge-holder-misc/page-2
Contacts: PM or Reply Here
As always, will trade for beer and/or alcohol too :woot::woot:
Item 5: Stock R33 Series II Stock Turbo
Price: $250
Comments:
  • Comes with elbow
  • Has minimal shaft play
  • No funny oil leaks
  • Exhaust wheel has not fallen off yet LOL
Reason for Sale: hash tag becauseracecar lol
buy my shit, will trade some stuff for:
  • 2x NEW Nitto NT-05 in 255/40/17
  • 6x 1000cc OR 1200cc sidefeed injectors
What has been done to the ECU? Was it socketed for a programmable EEPROM or Nistuned?
hey mate!
Socketed ECU with a reprogrammed ROM
Don't think anyone has installed the new Type 6 Nistune for R33 ECUs yet, I know a few of the Stagea boys have though.
Yeah I have done up a Z32 ECU with a Nistune board... but I thought a quick ECU swap for more boost would be a nice thing. I don't have the cash for a tune (and possibly never will) and i'm maxing out the AFM at 11psi. =-/
MMMMM will the clutch plate work in a jim berry pressure plate
Dooo it!!!!!!!!
Also ECU sold :)
Can't see why not? After all NPC pressure plates are modified Exedy covers :)
Dooo it!!!!!!!!
Also ECU sold :)
Dammit...snooze you lose :domokun: was about to PM you :( Mayb I should just keep saving and go the way of a PowerFC.. Goodluck with selling rest of your goodies
buy my adaptronic ECU and it will come with a free modded car for $12k :)
I like breasts
Stock Turbo & Dump $250
Clutch $200
Stock ABS Diff $250
Stock Rad $20
New Braided Oil Feed $50
Stock Front and Rear Sways $40
Stock S2 AFM $50
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
