Racv-Aomc Classic Showcase 2014 And Japanese Motoring Show
yeah that's it. don't mind what time. later the better :P
Not sure if you will see this or not but I think 8:30 and if I don't see you by 8:45, I'll just head off and see you there :P
I'll see you then. getting up now to wash my car yay
Yeah a few of us from CSA are helping marshal cars for that event, they expect a similar amount of cars 1000+ so should be amazing!
Yeah super keen if it's that big
btw didn't happen to get pis of the majesta by chance?
  • 10 months later...
well this year its on again and its this month too
http://www.aomc.asn.au/B&Eshow15.htm
theres also a focus on car clubs, might be worth bringing the flags down, people wear shirts, club details board etc? CSA had a strong presence last year.
http://www.aomc.asn.au/clubjudg.htm
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
