Found this on FB and noticed it wasn't here...
I thought why not try and get a few skylines together for a meet, take some good group pix then go for a little cruise to olympic park, then maybe somewhere after that if people are keen. I know this is a sunday, which is why please read the 'cruise to' info carefully.
WHERE: Crossroads Bunnings
WHEN: 4:00pm
CRUISE TO: Will be leaving Crossroads bunnings at 4:30pm and head to olympic park to get some nice group shots. will stay at olympic for aslong as we can avoid the rangers :P and who ever wants to have some late night fun/ driving after hanging out at olympic for a while, we can organise something then! if this event is successful then more will be organised, like big runs to places for dinner etc. make this a good event to show off the best cars that came out of japan!!!
More than sure i read somewhere this is a all skyline event, so the more we can get out the better :)
So far there is about 75 going but expect at least half of that.
https://www.facebook.com/events/1466891456862485/1470762503142047/?comment_id=1474627422755555&notif_t=like
https://www.sau.com.au/forums/topic/441029-all-skyline-meet-cruise-6th-april/
If it has a skyline badge your invited
And I'm going to say no R vs V bs this has to end now were all under the same banner and love the same cars thank you!
Come out will be a great cruise
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
