I used ARP flywheel bolts on my RB25 and they were fine. The packet they came in said they were for a 3S-GTE (toyota 4 cylinder) but they worked perfectly for me. Exactly what bolts were you using? A rebuild is better than losing your feet.
and yeah dude im super thankful nothing actually came off completely while driving/dynoing.....could have been devastating!
  • 3 weeks later...
As a target for you to aim for, my GT-RS makes 5psi at 2000rpm. However, I have a very trick exhaust manifold and run an external gate with the internal wastegate welded shut.
I also have tomei poncams in my RB25, though still run the standard lower runners with a plenum top similar in principle to a plazmaman.
attachicon.gifImageUploadedBySAU Community1401145700.635519.jpgattachicon.gifImageUploadedBySAU Community1401145773.255970.jpg
I also have this custom bad boy I scored going on so should also help a tad with better spool ....
Looks like an eBay stainless one.
I personally wouldn't use it. Stock is fine and won't crack.
It's definitely not an eBay manifold I've seen a few of them (they are puss) and the quality of this one is that of a professional. Not to mention I can't find any other manifolds bar one in japan that have the runner configuration of this particular one.... (three at back of motor)
make sure you strengthen/gusset it where you can...especially if your exhaust system isn't supported properly....a lot of weight hangs off it.... and they crack and warp.
  • 1 year later...
And nice 1 year bump. Good commitment.
Cheers bruh!! Haha I was pretty freakin stoked with the end result considering all the dramas I had then when it was all finally done no one said "nice effort" or anything at all lol sad panda
I personally haven't seen anyone else achieve this with a HKS gtrs so I thought someone woulda had some praise lol
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
