Hi all, since converting my s1 to a manual I've loved it, but for some reason- now this is very intermittently happening -it revs up to about 1500, sometimes up to 2000rpm when coming to a stop or very slow turn.
This is very frustrating when trying to slow down for a turn or roundabout, and stay in 3rd gear -but it's pushing like a dozer!
or you slowly pull up at the lights and it's pulling 2000rpm (and it's reasonably loud) and people are looking like what's this dude doing?
I've not been able to replicate the conditions or driving techniques to make it do this, it's very random.
Some days it will do it at every stop or slow turn/intersection.
Other days it won't do it at all the whole drive?
Sometimes it goes between this revving state and idle repeatedly while stopping (revving up and down every 1-2 secs)
I can only assume it has something to do with the auto tune?
Maybe it's revving slightly to maintain converter speed/pressure? (because it doesn't know any better).
The only auto mod I did was bridge the neutral switch in the engine bay so it can start.
Is there something I can do to the input signals to the ecu? Vehicle Speed sensor or something to fool it?
Any help on this would be great? As its starting to p!ss me off!
https://www.sau.com.au/forums/topic/441081-c34-s1-manual-revs-when-stopping/
  • 4 months later...
Sorry that I can't offer anything useful, other than to say what you probably already know: my auto does that, and I assume it's normal for the auto ECU. If you rev it in neutral even, after the revs fall, they will "blip" back up to about 1,500-2,000 rpm for an instant. I think it's part of the auto ECU setup. Seems to me that this is more than just tune - that there are extra "smarts" in the auto ECUs which are responsible for this.
  • 3 weeks later...
Ok, next question, does anyone know where to source an r33 style ecu plug?
I have a stock manual tune gtst r33 ecu here. Ill just re-pin the plug to use it.
Or-
Is the s1 c34 ecu nistune-able?
Or can I use a r34 neo power fc?
Im so over this issue I'm just going to buy an ecu with a manual tune!
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
