I blame Cadmoon, I had just read the above post when I was adding captions to some of the pictures :rolleyes:
EDIT: and don't worry, next cruise I come on there will be all these white/black/grey skylines and 1 bright red silvia.
We had a red cappacino. I think a Silvia would be a step in the right direction :P
Apparently a North side/ Sunny Coast cruise is already in the works...
  • Like 1
Don't you knock the Cappuccino Tony...it has turbo power unlike a certain Maxima.
Apparently it is... :whistling:
No. That's sedate and does what it's told. The Maxima just does what she wants. Oh look, a SLK, let's just point nose first at it!
Only because slow broken GT that shouldn't get off the highway.
Now you two just need to join *shakes fist*
I did say by the end of April and I held up our end of the deal :yes:
Just Zane. Nobody cares about Mel. :-P
Pfft... Life would be so boring without me being a pain in the ass :bunny:
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
