Guest barbie iz a bitch
Sorry for the hijack but I'm going to put my 1200cc injectors in before I put the HKZ td09 304/305 compressor housing wheel in the tubine housing wastegate because the efficiency of the thermal uptake is more likely to result in increased lag as opposed to response for my 5.43 AR housing outflow mechanism.
If you get what I mean.
:uhh: yeah I like queensland better too :confused:
  • Replies 101
:uh-huh:
:slap:
isn't it HKZi
I was thinking I might do the same, but use a 5.32 instead of the 5.43 for slighlty better spool time.
If you do that you'll run out of efficiency at 11,000 rpm or so. There's only so much egg a super NAWS cylinder can effectively evenly burnrate my arse hairs.
ps. I used to live at the top of McLeod st near the pool.
R u talking about cairns or am i having another blonde moment?
Right up the top behind the primary school where that kid got burnt with petrol. Used to catch mud crabs in the creek beside our house and eat them for breakfast with pineapples, mangos and avocados growing in the yard to keep us alive.
I loved the place. Also lived in Mareeba :ugh: for a while.
I think they are lice????  dunno.
haha You probably went to that school while i was partying around the corner.  Do you remember some really loud music stopping classes?  Greenslopes st?
haha there germs.
I wouldnt have a clue.. how old are you.. you were probably partying with my sister. she was a devil when we lived there :devil2:
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
