If your idle is 1000 rpm with the tps disconnected then you need to adjust the idle down to 750 before checking the timing again as it may be slightly different.
As for sounding like a wrx, generally if it sounds like that then a cylinder isn't firing, from either lack of fuel or spark. Did you disconnect anything to do with fuel or ignition when you did the timing belt?
I checked it with a timing light the usual way man
I just forgot to buy a spark plug lead when I was at sprints buying the new plugs
And yeah mad082 your right, ill have to check the fsm to find out exactly the rpm I need
Misfire ended up being coilpack wiring so it idles so nicely now
yeah just checked the fsm it says 650
but your right thats very low
so it says 650 and 15 degrees +/- 2
so ill aim for 750 and 15 ish
if i get that right does that mean its set up properly now and should be fine to drive?
thanks for your help guys especially cal, helped with heaps lately
car might make matsuri now haha
What do u mean , you just said 650 ?
Ive set it at about 750- 800 now, idle is about 18 ish degrees advanced
Ecu is still pulling the timing back when it's under load
Going to check for codes tomorrow, won't be surprised if I see knock sensor code
What do you mean "under load"? The engine isn't really "under load" at idle.
You don't get a "knock" code if you have knock, you get a "knock" code if there is a problem with the knock sensors or circuitry.
  • Like 1
so i think being an old 89 gtst my ecu only has one diagnostic mode
self diagnostics? or real time...
which is giving me the all clear, code 55,
but going up the road, its still running majorly retarded and the exhaust temp light is flashing and so is the ecu light
its just flashing randomly, not any particular code or number or sequence..
does this mean the old ecus are real time or self diagnostic?
like, do i have to drive it to pick up ecu fault codes, or does it log the last 50 starts or whatever it is and remembers if it picked up a code or not
because its giving me no codes,... but still running with no power
cant find much info on it, there is only info on how to use the diagnostics, not whether its real time or self.
or whether there is different modes or not
just read this like straight after
http://performanceforums.com/forums/archive/index.php/t-67188185.html
single led ecus record last 50 starts and will flash error codes from the last 50 starts
so ive got no ecu codes
yet my ecu is still retarding the timing,
also i forgot to mention, i relocated the fuse box and moved the battery to the boot at the same time as this work. probably important, but nothing on the fuse box was cut
i might try resetting the ecu and see what that does because the leds shouldnt be flashing as im driving.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
