Harro,
Item: 6x Yellow Jacks Ignition Coil Packs by Performance Wise (YJ-RB2526-S2) /
Price: $250
Comments:
  • All working and purchased from Performance Wise
  • 2x of the coils under 9 months old
  • Currently holds spark up to 1.15 bar
  • No cracks or anything, good condition
  • Built in Igniter
  • Will fit R33 GTS-t S1.5/S2 OR R34 GT-R OR WGNC34 S1
  • These ones: http://www.performance-wise.com/page27.htm
Reason for Sale: Upgrading to LS coils becausericecar and I want to run 1.5bar boost
Contacts: PM OR Reply Here
Have to see Terry, I believe I'm busy that weekend but if not I'll be there :)
Box not included, just used to store coilpacks till a buyer wants them
I'll throw in a spare coil too, it's a little and miss.
7th coil works ok when you crank up the dwell lol
these still for sale? are you willing to post? if so whats the cost to nsw 2307? cheers
Hey buddy, I'll bang them into an express post bag, tracked for like $15
  • 1 month later...
  • 4 weeks later...
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
