Previously on my S15 which produced 477.3 rw kws from a 2 litre. Never used on the road or drag, just dyno and shows. Should produce well over 500kw on a 6 cylinder (RB/JZ motors) In mint condition - almost brand new, lucky to have 1000km on it. NOTE: non roller bearing - RACING VERSION from HKS. The last model before the roller bearing version was brought out.
All i can say is OMG!!!
is it just the turbo itself or the whole kit?
CONAN, YOU OBVIOUSLY DONT KNOW WHAT A HKS T51R IS WORTH. A FULL T51R KIT IS WORTH WELL OVER 9K AUD NEW. JUST THE TURBO BUDDY, NO MANIFOLD OR GATE. LOOK AT DEANS POST "T51R SPL BB GTR KIT", HE'S SELLING FOR 6500 ONO 2nd hand.
i have a fmic, airfilter, bov, turboback zorst, and bleed valve,
what else do i need to make this turbo work with my system?
i have a rb25det
say i want it to spool quick and hold boost for long, without killing me engine etc.
help would be great
CONAN: The HKS T51R really isnt the right turbo to go with your cat back exhaust and air filter. Look at the power rating on this turbo, as per BMT's posts above and it should be clear to you that a full engine build would be required on an RB25 to have any hope of sustaining the power that this turbo can produce.
i have a rb25det
help would be great
:D :D :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl:
Remnis, do you have the dyno sheet that your monster produced?
Yeah, what Nick said... this turbo aint for the faint hearted :headspin:
Wouldn't mind seeing one of the more experienced members grab this a get a new project goin :aroused:
hay man i was just wondering i got a s15 getting pistons and rods dun.. got cam gears and cam shafts and other nick nacks.. what sort of lag would i get?
and if you had to sell it would you sell it with the manifold and front/dump pip and wastegate with it ?
If you wanted this T51R for your S15 i can sell the turbo and manifold only - dump pipe and front pipe should bolt straight on to your standard one, and the waste gate you will have to source yourself. Lag? mmmm Honestly you will have a hell of a time keeping it on the road. As for lag, with a non stroked sr20 i pushed 477 rw kw @ 1.8 bar at around 8300rpm. This turbo, depending on how big your cams are, will start producing boost at around 4800-5200rpm depending on how good your tuner is. Buy it buy it, i wanna see it street driven daayyym smoke a set of 285s in one burn out.
  • 1 month later...
please e mail me re this turbo [email protected]
    • Today, I'm a Breville BES920 tech, new triac board and new 3x way solenoid. Had overheating issues, home RCD tripping when it got warm, and the boiler stayed on when the machine was shut off. Also, usually 3x way solenoid chatter, this is the 3rd time I'm replacing it. Mind you, this machine is 9 year old and send it every day doing at minimum 3x double shots. When the in laws come over to took after my daughter, it will easily see 6x double shots in a single day. Tried to be somewhat compliant, crimped and then used a screw connector over the top. Would have preferred to use heat shrinks.   After all that, turns out all the overheating has damaged the o-rings to the steam tap as well. Ordered new ones, coming soon.
    • Still got it- First time checking sau in a while ahhaha
    • I don't know about that. I can hoon my R32 around - hard launches, high lateral Gs - with <<1/4 tank without any such shenanigans. This with the previous 040 and the current GSS342. I would suspect a fuel line problem. One of the hoses associated with the top of the tank perhaps.
    • This is amazing. Love that you’re giving the boys an intro to cars and off the screens. They probably have an insta for the car and build posts on TikTok for their mates.
    • It is.  Your car works fine with the tank full. If you drive like a Nana it works fine.  You give it a boot full with half a fuel tank, you get surge.  It 100% is a fuel surge issue. Maybe have a look at installing a Hydramat if you don't want to install a surge tank.  https://www.holley.com/products/fuel_systems/hydramat/
