one water line goes into the block behind the turbo....The other water line goes around the back of the head and into the back of the inlet manifold....its a pain in the ass to get to as there is a couple bolts in the back of the head....you can get with a 10mm spanner but it will try your patience...alot of people just cut it and attach a hose, isn't really the correct way to do it but it can work....make sure you use some heat proof hose though as it cops alot of heat...I used Gates flame proof, i think repco has it.....or wrap it with some kind of heat shielding...or use braided if you can get them..
The water line goes around the back of the head and into the back of the inlet manifold....its a pain in the ass to get to as there is a couple bolts in the back of the head....you van get with a 10mm spanner but it will try your patience...alot of people just cut it and attach a hose, isn't really the correct way to do it but it can work....make sure you use some heat proof hose though as it cops alot of heat...I used Gates flame proof, i think repco has it.....or wrap it with some kind of heat shielding...or use braided if you can get them..
you reckon you could give me a quick reference to a suitable exhaust manifold (internal)? as ebay has heaps of crap..
as i thought stock would be fine, and i have ordered braided lines as we speak lol.
ill take a look around the head/inlet manifold. pain in the ass to put my arm around there :/ ehhhh
Edited by Skyline_034
stock manifold will be ok if you want to use it... just wont really handle what the 3076 is capable of...you'd find the 3071 would spool up a little quicker is all and still make plenty of power...but dont stress if you already have the turbo
i found this. When the water line comes around the head, does it go where the green coloured hose is?
any other pics of where the water line goes? i cant feel it connect to a rubber hose at the back but i cant seem to reach/ feel it from the driver side
Yes and that hose is a bastard to get to in situ . It went on my 33 and in the end I had to remove the idle air control valve to get at it .
Nissan did it the right way on RB26s and piped it up to the front of the head on the turbo side and returned it into the top water outlet . Works well because any steam bubbles go out to the top rad tank and out past the cap into the overflow bottle .
A .
Well from what I can see, I can probably get some long nose pliers in there to take off the clip and pull off the rubber hose.
But does the braided line connect straight up or would I have to put a fitting between them? :S
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
