one water line goes into the block behind the turbo....The other water line goes around the back of the head and into the back of the inlet manifold....its a pain in the ass to get to as there is a couple bolts in the back of the head....you can get with a 10mm spanner but it will try your patience...alot of people just cut it and attach a hose, isn't really the correct way to do it but it can work....make sure you use some heat proof hose though as it cops alot of heat...I used Gates flame proof, i think repco has it.....or wrap it with some kind of heat shielding...or use braided if you can get them..
The water line goes around the back of the head and into the back of the inlet manifold....its a pain in the ass to get to as there is a couple bolts in the back of the head....you van get with a 10mm spanner but it will try your patience...alot of people just cut it and attach a hose, isn't really the correct way to do it but it can work....make sure you use some heat proof hose though as it cops alot of heat...I used Gates flame proof, i think repco has it.....or wrap it with some kind of heat shielding...or use braided if you can get them..
you reckon you could give me a quick reference to a suitable exhaust manifold (internal)? as ebay has heaps of crap..
as i thought stock would be fine, and i have ordered braided lines as we speak lol.
ill take a look around the head/inlet manifold. pain in the ass to put my arm around there :/ ehhhh
Edited by Skyline_034
stock manifold will be ok if you want to use it... just wont really handle what the 3076 is capable of...you'd find the 3071 would spool up a little quicker is all and still make plenty of power...but dont stress if you already have the turbo
i found this. When the water line comes around the head, does it go where the green coloured hose is?
any other pics of where the water line goes? i cant feel it connect to a rubber hose at the back but i cant seem to reach/ feel it from the driver side
Yes and that hose is a bastard to get to in situ . It went on my 33 and in the end I had to remove the idle air control valve to get at it .
Nissan did it the right way on RB26s and piped it up to the front of the head on the turbo side and returned it into the top water outlet . Works well because any steam bubbles go out to the top rad tank and out past the cap into the overflow bottle .
A .
Well from what I can see, I can probably get some long nose pliers in there to take off the clip and pull off the rubber hose.
But does the braided line connect straight up or would I have to put a fitting between them? :S
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
