Engine $6,800
Open to offers though
Speed sensor, pic please
Coolant reservoir cap? Ill only sell the lot together
Edited by Jezzza
Vspec II engine now $6,200 ono
Or take whats left of the car!
GTR body, some good panels. ALL glass
R34 GTR Vspec II engine, stock, unopened
Oilcatch can
Gearbox
Front diff
ORC 559 twin plate clutch
Nistune R32 GTR (R34 engine)
$8,300
Parts already removed..
Brakes and rotors
Suspension (drivers is stuffed)
Radiator
Shroud (gone)
clutch fan (gone)
Wipers
Front Reo (gone)
Brake ducts (gone)
Intercooler
All these parts with engine: $8,800
Edited by Jezzza
Price reduction and NEW parts!
New parts
- 3" min. cat back exhaust, one muffler and rear cannon, stainless steel, one dent in mid muffler - $200
- 3" cat with o2 sensor - $50
- RSR twin front pipes to suit RB26, 3" stainless steel - $300
- R32 Rear camber arms, unknown brand, look like white line - $150
- R32 GTR front diff - $400
- non-HICAS bar, unknown brand - $200
- R32 GTR OEM rear sway bar - $100
- R32 GTR OEM front sway bar - $100
- GTR fuel pump - $50
- GTR pump electronic senders and pickup - $100
Moving the BIG stuff, will be one of the last price drops as my shed is going up this month!
Wife wants to get it out of the house!.. so offer away!
- GTR bonnet - $300
- Passenger door trim - $30
- GTR Passenger seat with rail - $150
- Velo GP90 seat with rail (apparently S13) - $400
- GTR boot - $120
- GTR wing - $100
- GTR bumper with lights - $150
- GTR taillights - $40ea
- GTR rear wiper - $15
- GTR rear seats, top and bottom - $50
- GTR OEM front strut brace - $50
- Rear upper trim - $20ea
- Drivers elec switches - $50
- GTR 3 gauge cluster - $70
- Drivers door trim - $50
- Seatbelts - $40 the lot
- Rear boot lining + carpet - $30
- GTR AFM (one has broken tab) - $100 for both
- GTR headlights - $40ea
- ARC super induction box - $250
- GTR dash, and all associated trims - $70
- GTR wheel - $40
- GTR passenger mirror - $30
- Windshield cowel panel and rubber - $30
- Radiator silicone hose - $20
- Passenger elec window - $30
- Bilstein suspension, front drivers damaged - $150
If you require more pictures, please PM me with your number and part you are after
Cheers
Edited by Jezzza
Still have the N1 side pods avaliable!
These are not the rear pods, they are the ones that fit along with the side skirts
Genuine Nissan, one has two small cracks, very easy fix
$300
Hey mate,
I'm interested in dashboard along with main cluster, steering wheel, front and rear swaybars if new oem and maybe few other bits.
Can you send me some pics of the dashboard if its in a good nic as I have big bubbles and holes on mine.
Also your location and contact number willing to pick up tomorrow.
Thanks
Dave
PMs replied
Dash has small bubble passenger side above glovebox, I think pictures have it shown. Will get it out tonight/weekend
Main cluster = speedo? Its a Tomei unit, $350
I have the swaybars, OEM
Locations is Perth WA but can freight
**Refer to link in first post for parts available. If its not there anymore, it would be sold.
Some parts not yet pictured are GTR gearbox, twin plate ORC 559 clutch, front diff
I also have some misc. parts like A/C, P/W, swaybars, front suspension arms/hubs
Brake (ABS) master, cylinders, clutch cylinder
All glass available, rear is demister**
Edited by Jezzza
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
