hi guys, appreciate any input on this:
Does anyone know the difference between the Pro and the normal PowerFC? Is it that the Pro model deletes the AFM usage and uses only a MAP sensor?
Secondly, is the boost control offered by the Apexi PowerFC boost module THAT bad? If I can get a PowerFC second hand and the boost module is $150 for it (second hand), what reasons would I have to pay the extra for an AVC-R?
I only plan to run the stock turbo (so I guess 12PSi is safe limit?), is the boost control just dodgey with this approach, and I should use an AVC-R?
Thanks
Conrad
https://www.sau.com.au/forums/topic/4422-apexi-powerfc-or-fc-pro/
  • 3 months later...
I've just been to the nengun website and they are selling "GTS t R33 USED APEXi POWER PRO VERSON F/C H/C boost controller and greedy speed cut unit" for $1600
I want both a boost controler (so i can take advantage of my high flowed turbo) and a computer.
Should I get a normal powerFC for around the $1400 mark and get a seperate EBC (suggestions needed on what unit to get).
OR
get the above powerfc pro with its boost controller?
I'm looking at low 13sec 1/4s, and currently have turbo back exhaust, pod filter, high flowed turbo, hi flow cat, standard boost. FMIC goes in on thursday this week too.
Thanks for your input
Mark
From what I've read, it seems the pro has more load points and has the benefit of an auxilary rev limit which is great for consistant launches.
Ie. set the aux rev limit too 3000rpm, flaten the throttle and it'll sit there at 3000rpm until you start moving. Great for drags. :D
Here is a good read on SDU
http://forums.skylinesdownunder.co.nz/show...&threadid=20820
Yeah, but I'm sure it'd apply to the GTS-t's as well.
If in dought, drop APEXi in USA a email and ask them. But I'd be inclind to go with the Pro - not that I've ever been with a Pro :lol: :lol: :eek:
That'll be my next big investement on the car, a PFC Pro with the ad-on boost controler.
J
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
