hi guys, appreciate any input on this:
Does anyone know the difference between the Pro and the normal PowerFC? Is it that the Pro model deletes the AFM usage and uses only a MAP sensor?
Secondly, is the boost control offered by the Apexi PowerFC boost module THAT bad? If I can get a PowerFC second hand and the boost module is $150 for it (second hand), what reasons would I have to pay the extra for an AVC-R?
I only plan to run the stock turbo (so I guess 12PSi is safe limit?), is the boost control just dodgey with this approach, and I should use an AVC-R?
Thanks
Conrad
https://www.sau.com.au/forums/topic/4422-apexi-powerfc-or-fc-pro/
  • 3 months later...
I've just been to the nengun website and they are selling "GTS t R33 USED APEXi POWER PRO VERSON F/C H/C boost controller and greedy speed cut unit" for $1600
I want both a boost controler (so i can take advantage of my high flowed turbo) and a computer.
Should I get a normal powerFC for around the $1400 mark and get a seperate EBC (suggestions needed on what unit to get).
OR
get the above powerfc pro with its boost controller?
I'm looking at low 13sec 1/4s, and currently have turbo back exhaust, pod filter, high flowed turbo, hi flow cat, standard boost. FMIC goes in on thursday this week too.
Thanks for your input
Mark
From what I've read, it seems the pro has more load points and has the benefit of an auxilary rev limit which is great for consistant launches.
Ie. set the aux rev limit too 3000rpm, flaten the throttle and it'll sit there at 3000rpm until you start moving. Great for drags. :D
Here is a good read on SDU
http://forums.skylinesdownunder.co.nz/show...&threadid=20820
Yeah, but I'm sure it'd apply to the GTS-t's as well.
If in dought, drop APEXi in USA a email and ask them. But I'd be inclind to go with the Pro - not that I've ever been with a Pro :lol: :lol: :eek:
That'll be my next big investement on the car, a PFC Pro with the ad-on boost controler.
J
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
