hello i have a few problems with my Nissan skyline r34 gtt. when its under boost around 4600 rpm to 6000 rpm it is jumping around and kicks in and out. now i just check the spark plugs and they look stuff when they only not even 500ks old. has been tracked once and that's all. i just wondering if i could get some help out here.
https://www.sau.com.au/forums/topic/442403-rb25det-boost-jumping/
So you have a misfire at the most common room range ever discussed on this site?
Search and find your answer....
Or should we all guess randomly why your car is missing?
Seriously, search first. If for some crazy reason you can't find the information ask the question then.
And if you do need more help, specify what mods your car has. That will save people making wild guesses about the situation,and will show you are willing to take the time to help the people that are trying to help you.
I'll add a wild guess in, for fun. You are running more than 10 psi on stock ecu.
  • Like 1
So you have a misfire at the most common rpm range ever discussed on this site?
Edited by superben
sorry mate but a had look!.
new on this alright. and no i am not running 10psi. its running stock .also stock ecu
next thing the plugs gone.
it doesn't back firer it just stopping boost and jumping
So your car is 100 percent stock?
It really sounds like when boost is too high on stock ecu.
It could be coil packs as they crap out around this age of the car.
Do the usual things, clean and inspect cool packs, reduce plug gap to .7 mm, clean afm.
Do you have a boost gauge? I would check your waste gate lines are in good shape and not split which would cause higher boost.
so your thinking its boost oscillation.
yes it does have a boost gauge but it is off never on. well the spark plugs are really dark and having rust all over it as well. thanks mate
ya i have a look today then.
the car has only done 88000ks. plus it sit for over 3 years. but when the car has been running for a long time it does clear up a little
As I wrote I'm also thinking you are actually running higher boost than you think.
Turbos don't stuff up and make boost jump. Something else is the problem.
Also , check for leaks in the pipework,loose clamps etc. The only way to be completely sure of no boost leaks is to pressure test,so I suggest you Google how to pressure test intercooler pipe work. A boost leak would make it run way too rich and would cause the ecu to cut as you have described.
If it was coil packs, it would certainly pull the engine light & code 21 (primary ignition signal). Engine light will also stay on till code is actually cleared.
Is the engine light on?
Question 1: Does the problem mainly occur in second gear when going for wide open throttle?
Question 2: Does it boost ok at 4psi (stock boost level) BELOW 4,000rpm?
gavin when its below 4000 rpm its fine.
i think ben maybe right the is something making more boost or a leak.
but a month ago when i taken it for a drive the boost garage was hitting over 1k..
wtf the dam computer posted my comment when i wasn't finished.
what it was meant to say the boost garage was hitting over 1kg/cm on the stock garage then my boost garage was geting over 1.27kg/cm i am not sure if it meant to go that high ???? .
oh k well for plugs i have (PFR6G-11)
Google what that is in psi.......
Now you can see why trying to diagnose and help people over the net is a frustrating thing.
And the record shows my first guess to be correct..... what an achievement ;)
Edited by superben
Read my first post.
I can't believe I have to spell it out.
You are running to much boost.
Stock ecu has a spaz over 12psi.
You are running over 14 psi, yet in your first reply said stock boost when I guessed that you were running over 10 psi.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
