aim to get there @ 5.30 for scrutineering etc.
and you'll be out racing by 6-6.30pm.. all depending on the track.
that way you get a few quiet runs in (if the track is good) before everyone else gets there so you can have a good 3-5 runs in very quick succsession quite easily
nah, you'll still get runs, just not as frequent as if you were there early.
Also, around 7pm the big V8's get out with no exhausts and if your trying to practice it can be hard to hear your car with your helemt, let alone a thundering V8 next to ya.
thats why i go at 6pm, just to have a few quiet runs on my own without charg'd 8's gonig crazy
Hey Simon,
Ash is right, the earlier you get there the better, you get more runs in and have a much better chance running your mates...
Then again due to the weather, not many people attend, so either way you'll get quite a few runs in..... thats if it doesn't get cancelled from bad weather....
Good Luck!!!!
Thanks fella's. Hopefully it doesn't.
My mate with the Sti has just finished some major mods, and is warning us that he's going to whip the GTR?? :P .. But should be fun to see what the Benz does, another guy we know ran around a flat 12 with a chip upgrade and supercharged pulley kit.
After driving it, I recon the Merc should do about a flat 9 !!! :wassup:
Well maybe not but it sure feels grunty
Thanks Kev.. I think the only concern we have is how to get it off the line, "with or without the ESP" If the ESP is Off, forget it the thing will just sit there spinning. Maybe you want to run it for us?? :P
Rigga - It is stock.
OK, I guess I got nothing better to do tomorrow night, I'll drive it if ya really want me too.
HELL YES !!! :headspin:
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
