Hey, was doing a few laps a few weeks ago and by the end of the day when everything in the car was getting hot e.g. oil brakes etc, when i changed into 3rd 4th and 5th the gears would grind only when they where first getting into gear and under load.
they still did it on the way home when not under load but not as bad.. is it worth maybe changing oil for now and see what that does or you think synchros need changing?
ow and its an r32 gtr with 270 atw
Thanks
https://www.sau.com.au/forums/topic/443028-gears-34-and-5-grinding-in-r32-gtr/
What you want in your Gbox is Redline Shockproof Lightweight aka Smurf's blood.
It'll get rid of your problems and there are a million cases both on here and NS where this oil has solved grinding/shifting problems in Nissan gboxes.
I know it worked for mine like a charm and I had gone through 3 differents oils.
However, the oil is only masking the problem and ideally, you should be gunning for a rebuild with new synchros, parts etc...
So if you're looking for a short term fix while you save up the funds for a rebuild, this is your best option.
Awesome thanks just ordered some smurfs blood. Now this may seem a little bit of a noob question. Is it hard to change the oil. I know that draining is easy. But would re filling require a special pump?
A word of caution - LWSP oil is a GL5 specification oil, which apparently contains some additives which aren't good for the brass synchro which RB/SR/VG boxes run. Not sure how much truth there is to it, but I have a gearbox which was run on LWSP for a long time and the synchros wore out before any other components did.
I've since changed to a GL4 specification oil (new gearbox), although too early to tell if it will make any difference.
Redline make a GL4 called MT-90, Amsoil apparently make a good GL4 also, but I haven't tried it.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List:
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
