So after years of searching I am finally a 1999 GTR R34 V Spec owner. I still remember when I first saw the R32 as a kid, also remember asking Dad to buy the R34 GTR as a family car! This GTR R34 is my second Nissan after the Infiniti G35 Coupe 6 MT which is the V35 350GT.
So I have checked out at least a dozens of GTR R34, although this is not a perfect example in my book but it is the best one I have seen. This car has many mods on it some good some bad, but it is definitely a good car to start a build with! I am still new to the RB26, please feel free to make any suggestions!
Here is the current mod list:
Engine:
- N1 Block
- HKS GT-SS
- Jun cam 272 in/ex
- HKS 1.2mm metal head gasket
- Nismo fuel pump
- HKS fuel rail
- SARD 534CC injectors
- Tomei fuel regulator
- HKS intercooler pipping
- Trust intercooler
- Blitz BOV
- Trust radiator
- Tomei turbo outlets
- 90mm high flow stainless exhaust
- HKS F-con V-pro tuned by JUN (Koyama Tuner in Hong Kong who is retired now) for 1.4bar. auto cut off at 1.5bar.
- Trust profec B
- Trust turbo timer
- Nismo super copper mix clutch (700hp)
Handling:
- Brembo 6 pot Mono block 355mm GT brake kit
- Mine's Ohlin's shocks and springs
- Nismo sway bars front and rear
- Cusco control arms front and rear
Exterior:
- Nismo Replica Body Kit
- JUN Rear Spoiler Stand
Interior:
- Nismo White Speedo
- Nismo MFD
https://www.sau.com.au/forums/topic/443066-finally-a-gtr-r34-owner/
Looks awesome mate, the white Regamasters definitely set it off.
Where are from? Judging by the huge license plate somewhere in the EU?
:thumbsup:
Thanks mate!
I'm located in Hong Kong! Not too far from Australia. Yes we do use the UK style plates here since we are ex British Colony.
I actually didn't know those are called Regamaster.
I'm looking to replace a few things in the near future, such as:
Haltech
800cc injectors
OEM DV
Mine's or Tomei Exhaust
Mine's Front Pipe
Nismo LM-GT4 or TE37
I need suggestions to start this build!
Edited by etang789
  • 4 weeks later...
Finally removed that stupid looking Essential Vent to Air Oil Catch Can and replaced with a new stock washer fluid bottle, a new rear washer fluid motor, and a new OEM PCV Hoses.
Old Engine Bay when I first got the car
Current Engine Bay
Edited by etang789
The stock set up will be alto better than thermo's.
If its a modified engine then you may want to look at running a nismo or similar oil air separator.
The stock setup is already not enough for where I live, there is this local garage that had installed an extra electric fan that pushes air from the front of the radiator already. To clean up the mess, I think switching to 2 pull electric fan is the better solution.
Yes I am looking into getting Radium Engineering Catch Can, http://www.skylinesaustralia.com/forums/topic/443367-radium-engineering-oil-catch-can/
If we can do track days when it's 30 degrees with the standard fan and shroud then I wouldn't think you'd have an issue.
What are your temp issues at the moment?
its like 30-40 degrees here and very humid... I only see temp issue when in traffic or slow traffic up the hills, since hills are everywhere in Hong Kong. With the added electric fan up front now basically its always on when in traffic but MFD still shows a few degrees over the cruising speed.
BTW what does your temp gauge in the speedo show when cruising? Mine is slightly above the middle mark
I guess the humidity wouldn't help. My gauge always sits in the middle but the gauge on the dash is very vague. My water temp gauge sits anywhere between 75 and 85 degrees depending on what I'm doing.
I bet (as long as everything else is in good working condition) if you put a stock shroud on, your coolant temps would improve 'in traffic or slow traffic'. Additionally, if you have an N1 water pump, then that isn't going to help at low speed either.
Engine:
- N1 Block
- HKS GT-SS
- Jun cam 272 in/ex
- Nismo fuel pump
- HKS fuel rail
- Trust intercooler
- Blitz BOV
- Trust radiator
- Trust profec B
- Trust turbo timer
Handling:
Exterior:
Interior:
- Nismo MFD
LOVE the car , I have the same cars as you, the 350GT Skyline added Twin Turbos and now a Black R34GTR and about to put the RB30 Block and Nitto 3.2Lt stroker kit in, should be a fun car. Add the Advan RS-D machine/gloss black rims and all done.
Here is my ex Nissan, Infiniti G35 aka 350GT Skyline
Never seen a white one, I think I would like my R34 to be a lighter colour as it gets hot very quickly in the sun, as do most cars but black is the worst I have owed , black yuk but looks so great cleaned, trouble is they even get dirty in the garage so I made a cover so I can easily put it on and off, photo , works a treat.
Both fun cars to drive, it will be interesting to see how my new work goes on the R34GTR
Finally ditched my old exhaust and installed Mine's Front Pipe Pro and Mine's Slience-VX Pro Titan III and Venom 100Cell 5" Body High Flow Catalytic Converter
Much more civilized sound didn't get to redline it yet, still waiting for a proper tune before I can blast this exhaust in the tunnels!
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
