  • Replies 59
Thanks Greg! Picked up my front strut brace for my R33 GTS25T today. Very nice! Great service too mate! "Highly recommended" :uh-huh:
same here too. Strut bars are good quality amd service is second to none.
  • 1 month later...
no problems guys
pls bear in mind that THESE PRICES INC POSTAGE! ($15-20)
hence they are the same price as the so called 'group buy'
just a thought!
Don't be nasty now!!!! Bit of competition doesn't hurt anyone. It actually benefits the buyers. Think of the buyers!!!!
Which i am,
No need for people to wait, available 24/7 without ANY WAITING for so called ‘groups’ to organize themselves :ufo:
ciao
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
