Will do.
First round was two weeks ago. Track is very narrow and is really hard to pass. Only 10 on track at a time. Practise I was 8th. I qualified in 6th. Finished the race in 5th but also set the second fastest lap time for the night.
Apparently all the other guys are regulars apart from me and one other guy so I'm pretty happy with that result.
Hoping to be a little further up tonight. Fingers crossed! :)
  • Like 1
So with no other votes the track that got chosen for tonight's final SViRC round will be - Laguna Seca (USA) - the track was picked from a sophisticated randomizer called a 'beanie' with the track names inside. See you on the track from 8pm for prac :)
How'd you go last night Tony?
I qualified third last night. Finished in third and also set the fastest lap of the night in the race. Was a little bit faster than the car in 2nd but couldn't find a spot to pass cleanly.
I wish we had more tracks in Canberra so we could mix things up a bit, but there's not a lot I can do about that.
Thanks for the race last night Tony.
The the new tyre model is interesting as a couple of times the car slipped without notice, also seemed like it ran out of brakes as well especially lap 16 when you was behind me into turn 1.
Was a fun clean race, bar my spinning :P Gary and I had the track to ourselves. My brakes started to go around lap 13 and my butt went numb lap 14, was interesting fro there on in! :P
Awesome result Chris, was it indoor or out door? Our last Karts event with SAU Vic was an inside track and seemed from what driver said was little slow.
PS. Will post last nights results and a series wrap up by weekends finish :)
Glad to hear you guys got to fight it out. Interesting that the brakes were fading. Which car were you guys in?
This place is indoor. The karts get up to about 70km/h and they're all electronic so they're fairly torquey. Turn one is a nice wide 90 degree left hander that you can do with the throttle flat, so the track isn't too slow.
Here are the results from the last round of the 2014 SViRC, the smallest field of the season still saw some fun and interesting racing due to a new iRacing build.
10750155_10153523743974386_6228807684550
Championship results are -
10730982_10153523744134386_7070077542290
So congratulations to the top three drivers, trophy presentation date will be announced soon.
With the first season of the SViRC all finished up I would like to thank all those who participated, whether it have been for every race or just a few laps, everyone who got on track made the series what it was. With fun and safe racing every round it was more than enjoyable racing visiting virtual tracks from around the world.
Hope to see people back next year for the 2015 SViRC season!!!
  • 1 month later...
Hi all, hope your holiday break has been great! The trophies for the 2014 series have not been forgotten about. They will be awarded at the 2014 SAU Vic awards nights which will be announced soon.
In the mean time head over to http://www.sau.com.au/forums/topic/452253-2015-sau-vic-iracing-championship/ and check out the 2015 SViRC season! Hope to see you all on track :)
  • Like 1
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
