I'd like to start with I'm in no way condoning street racing and simply asking for some opinions. So I'll start off with why I've made this thread. I'm trying to figure out if I have stock GTR turbos, I imported my 1991 GTR last year and was pretty much bone stock with 128,000km. It had the 100,000km done in Japan came only with Work Equips, St. May Jasma exhaust and thats it, even stock air box. The car now has 18x10 Work XD9 wheels, Tomei Titanium Exhaust and Apexi intakes. The car came with the stock boost restrictor in so I removed that also.
From what I've read a R32 GTR with exhaust, intake, boost restrictor out should make around 350 hp at the crank. I've raced multiple Subaru STI's of all years 2004, 2006, 2008 all with a cobb stage 2 kits and have beaten every one by at least 2 cars. I've raced a couple SR20s from a roll and it's also not even close. But recently I raced a friend with a 1998 BMW M3 with a stage 2 supercharger with dyno sheets showing 420 hp @ the crank so probably around 370 whp. From a dig it wasn't even close but from a 40 roll by 4th gear I was ahead by 2 cars and I had misfire.
So i tried to take off some pipng to see if i could find stamping on the turbos but it's damn near impossible to see anything. So i'm looking for opinions if you think there stock or upgraded. Feel free to say what cars you have raced with your basic bolt on GTR.
https://www.sau.com.au/forums/topic/443596-r32-gtr-vs-m3/
-> Speed off the Streets -> Wakefield or Winton
If the restrictor was still in it is a very high percentage that your Turbo's are stock.
- and with what you are doing wont be long before they blow the ceramic wheel off and/or you do a big end bearing)
Your first engine rebuild seems not too far away !
https://www.sau.com.au/forums/topic/443596-r32-gtr-vs-m3/#findComment-7294986
I see I've attracted some trolls. Sorry for being so basic but company's do offer "stages" although I probably shouldn't feed you, I clearly stated he has dyno sheets of his car and these numbers are not made up. Putting all that behind us it has a Active Autowerkes Stage 2 Supercharger kit(Rotrex C38-81 Supercharger)
https://www.sau.com.au/forums/topic/443596-r32-gtr-vs-m3/#findComment-7296354
I had a 99 E36 M3 evo manual with 255rwhp (catback, flash tune) and mate had a 33GTR with 246awhp - 14psi untuned, catback and intake.
GTR pulled on M3 by a little bit. On track of course...
Your mate with the supercharged M3 can't drive or is bs-ing.... Or your car is tuned at 14psi (1bar) and making 310-320rwhp.
https://www.sau.com.au/forums/topic/443596-r32-gtr-vs-m3/#findComment-7298506
Thanks for the reply, No markings on outside of ecu heres a couple pictures off the inside.
https://www.sau.com.au/forums/topic/443596-r32-gtr-vs-m3/#findComment-7299448
Stock gauge reads 1 bar
I'd say stock Garrett T28 Turbo's with restrictor removed.
Iv raced many comos with 400+hp and beat them with only 370-380hp turbo power is diffrent from v8 power
The difference between those power figures (400+hp Como VS 380hp GTR) are marginal, you would have bet them due the launch of the 4WD system and the low down response of the stock turbos.
And there might have been a weight difference between the cars (generally speaking, without knowing what both car set-ups are).
https://www.sau.com.au/forums/topic/443596-r32-gtr-vs-m3/#findComment-7299505
OP reads like he is in the US / Canada where the dynos read higher than here as well...
GTR would have edge over the average 400+ hp Commo purely based on AWD and the fact that GT-R owners don't tend to cheap out on tyres / useless big rims. Weight wise, if it's pre VE then it's almost the same.
https://www.sau.com.au/forums/topic/443596-r32-gtr-vs-m3/#findComment-7302373
    • Yes that’s what im trying to decide. Should I do stock gtt box or enclosed or open pod.
    • Also, I note OP is in Melbourne, which begs the question... are you aware of how illegal your car will be with a turbo, and intercooler and any sort of filter change? I don't know how you can get past the "2 intake mods" "rule" that seems to exist in Vic. Fully engineered might or might not get you there.
    • If you have a turbo... then the ducting holes I used to feed the pod are not available because your intercooler likely uses them. If you have an intercooler, your IAT's are going to be goverened by how good your intercooler setup is. I'm yet to really see anyone check IAT with a snorkel/boxed pod/proper CAI versus and unshielded pod. It would be interesting! But I suspect that the differences would not be so noticeable as if you were N/A as the intercooler is where the air is being cooled.. and out in front where the FMIC would be is a pretty good spot for it.. When I was turbo I pushed the stock GTT box as far as I could and made some pretty good power out of it, and noticed on the street I never made the same power/boost. Then I did a before and after run with a pod filter versus the box and picked up about 9PSI from the same boost duty cycle and about 50KW instantly. I never ran the stock box again, and recently removed it for my N/A setup. The box is restrictive to a degree - Even with the V8 setup I noticed I picked up power by removing the box completely, so punching holes from the bottom of it to get air from the passenger guard *helps* but the most effective one in my case was simply having the ducts, a pod, and no box around it. In my experience, *more* air was better than cold air. The air (with ducts) will be cooled off as you start moving, and especially if you start moving fast (a race track). It actually moves around quite a bit as you can see.
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
