For sale is my 1997 Nissan Pulsar VZR. This car was specially sourced and imported by Iron Chef Imports and complied by JLM. I am the first Australian owner.I bought the car in
August 2012 with 62 000 genuine KM. This car was completely stock and has a full Japanese logbook service history from the day it left the Nissan dealer. It has been my daily and now has
88 xxx KM, and has been serviced every 5-10 thousand Km. All servicing has been carried out by JLM. The car now runs beautifully as i have spared no expense in
maintaining it, and since owning it i have replaced the following:
- Clutch
- Front brake Rotors
- All four brake pads
- Left and right front, outer CV boots (october 2013)
- Rocker cover gasket
- All coolant hoses
_ Radiator with SSS core (nov 2013)
-Front engine mount
-rear engine mount
- Vct solenoid (may 2014)
This car is a non accident car and the body is in excellent condition. Since owning the car i've had two panel beaters inspect the body and both have found that all
bolts , welds, seals and panel gaps are as per factory. The doors, boot, bonnet and guards have never been removed, and the chassis is very straight.
post-95869-0-56158000-1400984233_thumb.jpgpost-95869-0-34228200-1400984272_thumb.jpgpost-95869-0-42859300-1400984399_thumb.jpgpost-95869-0-88320700-1400984424_thumb.jpgpost-95869-0-30619100-1400984470_thumb.jpgpost-95869-0-99195800-1400984506_thumb.jpgpost-95869-0-42067000-1400984537_thumb.jpgpost-95869-0-90748800-1400984571_thumb.jpgpost-95869-0-43264800-1400984600_thumb.jpgpost-95869-0-69028000-1400984662_thumb.jpgpost-95869-0-33754600-1400984692_thumb.jpgpost-95869-0-61728200-1400984728_thumb.jpgpost-95869-0-58038600-1400984757_thumb.jpgpost-95869-0-23130700-1400984790_thumb.jpgpost-95869-0-85212000-1400984826_thumb.jpgpost-95869-0-43519700-1400984857_thumb.jpgpost-95869-0-03699200-1400984886_thumb.jpgpost-95869-0-75137300-1400984916_thumb.jpgpost-95869-0-82171600-1400987197_thumb.jpgpost-95869-0-16010700-1400987247_thumb.jpgpost-95869-0-23398900-1400987587_thumb.jpg
Having previously owned an Aus delivered Pulsar SSS, i can tell you that the performance of the VZR is considerably better and the NEO VVL also provides better fuel
economy. The VZR is also cheaper to Insure as it's 1.6 L engine does not classify it as a sports car. In short a perfect P Plater Car or a great daily that's still
plenty of fun on the weekend.
Car has 6 months rego.
I am selling to make way for a skyline. :D
All inspections are welcome, this is a very clean and original car. Condition will not dissapoint.
Location - Sydney
Price-$ 10 000 ONO
Please PM me for contact details.
Jason
Edited by the spruce moose
https://www.sau.com.au/forums/topic/443605-pulsar-vzr-sr16ve-iron-chef-sourced/
Recently i was given the figure of 12k to import a car similar to the condition of mine by JLM, that is if you are able to find one without accident damage.
As per the rules, if you are not interested in buying the car DONT post.
Thanks
nice clean example.
jump on http://forum.pulsar.org.au/forum.php maken an account and advertise. will be more likely to get interest there than here.
https://m.facebook.com/story.php?story_fbid=655958541140055&substory_index=0&id=109130862489495
Not sure if the link works, but it's for a n1 VZ-R selling for 12.9k.
Guess I will have to eat my words.
  • 4 weeks later...
  • 2 months later...
  • 1 month later...
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
