Hey all... sorry i have to pull out from the Recon Cruise... "Work" calls... sigh... Have to live a website this weekend... this sucks...
its ok just be free for the actually cruise :)
  • Like 1
Sounds good I'm in. Keen for my first SAU cruise :)
I’m guessing you'll reschedule if it's raining?
Good to see the new boys getting involved too.
Will depend how much rain to be honest. If it rains a lot in the days before or the day of the weir in the national park will be closed and we'll probably have no choice but to cancel. Best advice is to always check the thread as much as possible in the days before and on the day so you don't miss any info
Ahhhh !! You said the " r " word.
I have scheduled for the day off for the last month and a half.
Im going rain snow or shine, however if it IS raining, we wont be going through the nasho, we will shortcut down the freeway to stanwell tops.
Obviously we wont have as good a turn out in the wet, but i will refuse to let the day down. The few brave souls who turn up ( if there is bad weather ) i will find a more relaxed spot to finish the day.
Here's hoping the weather is just windy or overcast.
I will make another statement saturday 10-11am, and again at 8:30 after i finish work.
There is a request for a highlands/wollongong meet up on the way to loftus.
Can i please have an indication of interest for this please? I am intending on being at loftus around 9:15 to attempt to be the first car there.
This would constitute a meet up at yallah shell around 8:00 -8:15.
Any updates to the meeting points along the way? I might wake my car up and bring it out but won't be going anywhere near the nasho, imo going through there is asking for trouble.
I'd be leaving from Turramurra so if anyone is keen to meet and head down beforehand, drop me a pm.
If your not keen on the nasho, you can always cut through helensburgh to stanwell tops, were we will be stopping for photo's.
I will be doing the pre cruise this wednesday, and timing the trip so that i can advise on intinery.
As stated, will be a good update the afternoon/night before.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
