Need this gone
Delivery: 5 days by EMS
Garrett GT3576
Really rare Twin Scroll T3 AR.75 turbine housing
Garrett GT3576 T3 TS AR.75
Compressor Size: 6 blade 53mm/76.2mm
Turbine size: 68mm/60mm
Compressor flow: 55lbs/min (max 500-550hp)
100% Genuine
Journal bearing (not ball bearing!) Rebuildable. Barely noticeable spool difference when wideopen throttle compared to bb. ~300rpm max
Oil cooled centre core with 360degree thrust bearing
Capable of 450-550hp
Price: AUD799 Delivered to your door
Pay via paypal
PM me for details
Open to reasonable offers
Edited by robots
https://www.sau.com.au/forums/topic/443790-fs-garrett-gt35r-t3-twinscroll-ar75/
Tuned on stock rb25. E85. 20Psi drops to 15psi, due to weak springs in wastegate. Has more stuff in it.
200rwkw@4000 250rwkw@4300 no less than 257rwkw from 4700 to 6500rpm.
On the road it will come on even faster.
1512532_10154223773280304_66706785887106
10390962_10154223772610304_1640947737774
Still got one in my stash. Ready to be sent out.
    • Yeah, you need to do it properly. You need to start out slow and gentle, ramping it up until they are good and hot, but not cooking, then roll off the other side (instead of letting them cool down quick).
    • I think yeah less hot fuel dumping into the top of the tank that wants to evaporate easily, fewer connections/hoses for permeation. Something like that. Also lower cost/easier production. Even my 2000 LS400/Celsior is a deadhead system. A single fuel hose to the fuel rails which have pulsation dampers attached and no return line.
    • I might do a few more high temp bed ins as described here.  I have a nice quiet 80kph road right near me.  How To Bed-In Your EBC Brakes For Street Or Track Use - EBC Brakes https://share.google/AjnOTILXoiqQnLu8p
    • I did a few 80-0 stomps. I then just rode the brakes while I applied throttle for a while to get them nice and hot. I live on a big hill and have been down it a few times also with stomps and brake riding.
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
