  • Replies 77
Popular Days
300wkw is easily attainable on your current engine, without much in the way of lag. Why do you feel the need to burn cash? Throw some my way please. :)
lag isn't much of a problem it's like foreplay to me and I simply want a 25/30 because I have all wanted to have one and know I have the means to build one
But that was my other question was what would I need to make the 300 mark on what I have now ?
A turbo
3 inch zorst
Hard intake
Some way of tuning the engine
Injectors
And a fuel pump
Anything else I have forgotten?
stick with the 25 head..spend the money elsewhere (turbo?).. you'll make 300kw pretty easy with the rb30det and right turbo.
don't bother with an adjustable FPR....just stick with the stock one and upgrade your 550's.
Edited by Badgaz
Well I have a 3 inch with v band bigger turbo injectors and fuel pump as well as apexi power fc and was just speculating that I all ready have these as in a comment ^^ and only making 250
Some people have that and make 380kw.
It has something to do with the turbo choice.
Bigger turbo isn't very specific. I assume it's hardly hardly any bigger and that explains the the power.
Bigger decent turbo.
Much power.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
